Question about Epson Office Equipment & Supplies
Clean sensor I have an Epson LP-S5500. I love it - until it hiccups! The message it is continually displaying is ''Clean Sensor'' (B Cleaning ''bar''). I have. And I did it again...multiple times. I even pulled out the A Cleaning ''bar'' several times. I also recycled power a couple of times. But - this morning: All's well! Any suggestions on how I may prevent this from occurring again? Thanks!
Metawatch
  • 96 Answers
SOURCE: Epson Stylus CX6400 not printing
The head assembly is attached to a photo sensor that tells the printer when it is at the ends of its travel.
Sounds like this mechanism is not working properly.
Check to make sure thare is no obstructions or dirt in the paths at the ends of the print head travel.
You can use an air gun to clean the printer (JUST KEEP IT AWAY FROM THE PRINTER CARTRIDGES) as the ink will FLY EVERYWHERE.....
Posted on Feb 09, 2008
  • 41 Answers
SOURCE: Dell All-in-one 924 error: "right cartridge is incorrect"
Hi ,
if you are getting the error msg 12203 , pperform the following steps,
remove both the cartridges from the printer and unplug the power adapter ( black box) from the back panel of the printer, clean the cartridges using a damp cloth .
initially put only the black cartridge and then turn on the system , it will give you the error msg right cartridge missing, you can ignore it and try copying a document .
remove the black cartridge and put the color one in, and then try printing.
during the printing with any of the cartridge inside the printer if it gives out the error msg 1203 then that cartridge has to be replaced...
Posted on May 01, 2008
jacklee366
  • 541 Answers
SOURCE: Epson R320 "General Error" message - unable to clear
try downloading the ssc this will reset your printer
Posted on Mar 03, 2009
hari007_in
  • 138 Answers
SOURCE: I have a 13 month old HP Photosmart C5180 which is
your second set of catridges mush help you,, and also,, it seems that your operating system is corrupted,, its better you reinstall the printdrivers first,, if problem persists,, then try reinstall of windows..
Posted on Sep 28, 2009
  • 31 Answers
SOURCE: my epson stylus photo rx585 states printer error
its an internal problem of the printer. some part inside of it may have been faulty.
Posted on Jul 06, 2010
Getting message error 0001000C on Epson Stylus Pro 9800 right after is done printing. The next print after message (after i turn off and on the printer) appears with double image on some areas.
its a carriage home position sensor error u have to clean the sensor and the stip guide which has been attached on carriage... its due to dust on sensor.
Oct 17, 2013 | Epson Stylus Pro 9800 InkJet Printer
When car is warm engine races at idle.
it is possible the engine to have a vacuum leak,**** air,or the temperature sensor not to work properly and give wrong message to PCM as cold start. clean also the throttle body from any dirt.
Aug 31, 2012 | Cars & Trucks
Display message Carriage jam: open door, clean carriage jam and then press OK to continue
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 21, 2011 | Office Equipment & Supplies
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Hope that the manual contains everything you need from nozzle check to sensor errors.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
2003 Ford Focus will not idle
try cleaning the MAF Mass Air Flow sensor element wire in tube with a toohtbrush and carb cleaner carefully. It gets coated with a film. It is in air inlet hose and has a wiring connector on it. Then drive for 15 minutes so it can learn the clean MAF sensor. Is check engine light on?
Removal
  1. Remove the air cleaner outlet pipe.
  1. Disconnect the mass air flow (MAF) sensor electrical connector.
  1. Remove the MAF sensor.
Installation
  1. To install, reverse the removal procedure.
Otherwise, you may need to adjust idle air control (IAC).
report on results.
Mar 19, 2009 | 2003 Ford Focus
Aculaser C2600 "clean sensor" message won't clear. Have just replaced K toner and it printed about 300 copies then stopped with the message. opened cover and closed it but after calibrating the message...
This is a common characteristic which arises from using improperly remanufactured toner cartridges.
Otherwise it is a bad Epson original one - which is highly unusual!
When the C2600 runs through its calibration it prints strips of each colour on the transfer belt which are sensed for density. You will get a "clean sensor message" if the reading for any of the strips drops below a certain value.
The first thing to do is to depress the clean sensor lever behind the front cover several times . If that doesn't fix it I would advise you to remove each cartridge in turn (go to reset menu and scroll down to change toner) and inspect the toner on the surface of the roller. If there is any form of "sheen" then you'll need to replace the cartridge.
It is possible to adjust the doctor blade if you know what you're doing but be careful as there are shims on each side. Loosening and moving the blade bar towards the roller slightly, refixing and then turning the side cog to rotate the roller can sometimes resolve problem. Not a good idea really unless you're in an emergency.
There are some good remanufactured cartridges and bad ones. If you want to avoid this buy genuine Epson cartridges - I know they're expensive but what does the down time cost!
Jan 14, 2009 | Epson AcuLaser C4100 Printer
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Epson Aculaser C9100 Colour Laser printer
If you changed the bottle and rebooted the printer with no change, it could be that the sensor for the bottle may be faulty. Try cleaning it:
1. Remove the CASSETTE ASSY.
2. Open the COVER ASSY FRONT.
3. Remove the two screws (silver, flanged, 8mm) that secure the COVER over the sensors. Remove the Snap from the main unit Frame, and remove the sensor COVER.
4. Use a paper towel or cloth to clean the sensor area of any dust or toner
Nov 08, 2007 | Epson Aculaser C1100 Printer
E4 Error Message
ok sir! are you sure is the sensor are cleaned? your unit need to general cleaning specially the sensors!
Oct 16, 2007 | Kenwood KW85 Air Conditioner
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
