Question about IOGear Computers & Internet
How in the Hell is one supposed to understand the instructions for the IOGear GCS932UB. I cannot get the unit to detect my powered usb hub. No information is displayed when you try any function so I never know where I am in relation to PC or Mac. I have a Mac Desktop and a Mac Mini connected to a single monitor. I can switch with the remote switch but cannot use my uSB hub
  • 30 Answers
If you trying to use the USB hub through the mouse port of the KVM make sure the mouse emulation has been turned off. This can be done by tapping Scroll Lock + Scroll Lock + m + Enter. This turns the mouse emulation off and causes that port to act like a direct USB connection to the computer. Instructions for this can be found in the user manual on page 14.
http://www.iogear.com/support/manual/GCS932UB_Manual.pdf
Posted on Jul 26, 2010
What is this unit used for? do not understand why I should use it
It is like a power strip. If you only have one USB socket and you need to attach multiple USB devices, this is what you would use.
Apr 12, 2011 | Dynex DXUH234 4Port USB Hub
I have a model m01517 5 port usb hub. It has 2 usb cables to the computer, do I use the blue or black connector? I can only get one port to recognize a device plugged in the other four seem to be dead,...
Not sure I understand this hub either. Looks like only one port is a USB 2.0 port, but here is a snippet from the manual......
This iConcepts USB Hub provides the electronic interface between USB devices and the host, It allows up to five USB devices or Hubs to connect an upstream USB Hub or Host port.
Features
• One USB 2.0 port
• 4 Port USB 1.1 and support high speed (480 mbps) and 4 port full speed (12 mbps) operations.
• The USB 2.0 port can operate both USB 2.0 & 1.1 Devices
• USB 2.0 port supports self powered mode and bus - powered mode, indicated by a powered LED .
• Over current detection and protection
Manual is provided here: http://www.sakar.com/p-1124.aspx?categoryid=182
Sep 09, 2010 | Sakar (M01517) 5-Port USB Hub
Can't access Ion Drive
You have to check also Disk Management while your HD is connected to the your computer.
First, if you can detect the HD in your Device Manager but not under the Disk Management, then the IOGEAR Tech Support is could be correct.
If that's the case, you need to contact IOGEAR and ask them to send you a USB Y-Cable. That Y-Cable is FREE. IOGEAR will just ask for your billing address, and they can send you one for free.
That Y-Cable has two type-A USB and one mini-B USB ports. The two type-A should be connected to the computer, and the other end to your HD. Having two USB connected to your computer, that should be enough for the HD to get power from the two USB ports.
If that did not help, I would suggest to connect your HD into different computer to see if you can detect it.
If you do detect it, back up all the files, reformat your HD, change the drive letter, and then retrieve all the files back.
Thank you and good luck!
Feb 18, 2010 | IOGear 2.5" Hi-Speed USB 2.0 ION Drive II...
Iogear 4 port USB 2.0 HUB (Model GUH285) now working properly
I think it clearly states that the device is defective.... you need to call IOGEAR for RMA if its still under warranty
Jan 25, 2009 | IOGear 4 Port Hi-Speed USB 2.0 Hub
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
IOGEAR COMBO not recognised
Is your hard drive detected by the computer? Did you try changing the USB ports? You can check if the drive is detected by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your drive. If you dont then the drive is probably not detected. If you see, you can just re-format it from here and it will appear in your my computer.
Dec 21, 2007 | IOGear COMBO ION GHD135C160 160 GB Hard...
IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link: http://iogear.com/support/dm/driver/GMFPSU01#display
Nov 13, 2007 | IOGear GPSU21 Print Server
DELL STARTUP
There was problem at one time with IOGear KVMs not working correctly with the USB chipset on the Dell motherboards. This problem was resolved by using a USB hub between the KVM cable and the computer. The user could take the USB portion of the KVM cable and plug it into a USB hub and then take the USB hub and plug it into the Dell computer. That should help with the problem.
Oct 16, 2007 | IOGear GCS632U 2-port KVM Switch
Open Questions:
Computers & Internet Logo
950 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
