Question about ViewSonic VX1932wm Monitor
3 shaded vertical bars on monitor about 3 inches
How to remove 3 shaded vertical bars on monitor about 3 inches wide each on ViewSonic VX1932wm monitor?
  • 11,361 Answers
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 25, 2010
How do I remove the back of my ViewSonic VX1932WM-LED monitor
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Oct 03, 2014 | ViewSonic VX1932WM LCD Monitor
Vx1932wm-led background lighting goes out
That is a very common symptom of a failure in the power supply board. This model uses the same power supply board that the VA1930 model uses. Here is a link to repair information that shows what capacitors to replace on the power board to repair it.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=168
I hope this helps,
BuddyMc
Jul 20, 2012 | ViewSonic VX1932wm Monitor
Monitor screen is snowy and has a vertical bar 2
This could be either your screen is failing or your grahpics card
Jul 04, 2010 | Sony ® VAIO® V TV-PC Series -...
I am getting vertical bars moving up on my screen
vertical bars in video can be caused of poor filtering of voltage on the power supply,you need to open the back of the tv to repair the power supply.replace all bulging capacitor this causes the problem.Tnx
hope this help.
please rate my help.
Jun 05, 2010 | ViewSonic VA1912wb 19" LCD Monitor
How Do You Fix This Kind Of Monitor For ViewSonic VX1932wm LCD http://s928.photobucket.com/albums/ad126/vtamvo/?action=view&current=100531-161032.jpg
Check the caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
By the way, your link does not work.
May 31, 2010 | ViewSonic VX1932WM LCD Monitor
Wide, snowy horizontal bars scrolling on Viewsonic VA1912WB
Changing computers doesn't help. Followed all suggestions from Viewsonic Tech Support. Problem is in monitor circuits--had to replace it.
Dec 23, 2009 | Acer AL1916W 19" LCD Monitor
ViewSonic model vx922 monitor, how do I shift screen to right.
You may want to look into your video card settings about the vertical settings. Most monitors usually have just a millimeters off. I suggest to contact your computer manufacture or video card manufacture.
Feb 22, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
The screen resolution
Your going to love this. Open control panel, open display. Click the settings tab. Click Advanced. Click the Monitor tab. Remove the check mark from "hide modes". Click the drop down menu & set it to 75 hertz. Click Apply & than ok. You are now back to the Settings window. At Screen resolution move the slide bar to more. Pick what you want. Again click Apply & than ok. Bingo there you are! Have a nice day.
please vote...
Nov 18, 2007 | ViewSonic VA1703wb Monitor
ViewSonic VX1932wm Monitor Logo
105 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
