Question about LG 55LH85 LCD TV
LG 55LH85 55INCH 1080P 120HZ LCD TV. HDMI
LG 55LH85 55INCH 1080P 120HZ LCD TV. HDMI INPUTS: NO SIGNAL AFTER THUNDER/LIGHTING STORMS OF DIRECT TV AND BLUE RAY. HAS HAPPEN TWICE. ONLY TV AFFECTED IN HOUSE
4 Suggested Answers
  • 8457 Answers
SOURCE: Could somebody tell me if this TV will work in
Yes,u buy this tv in the US?Argentina run on NTSC frequincies,the tv should work find.
Posted on Jun 08, 2010
  • 81 Answers
SOURCE: When i try to play a Blue Ray DVD, the LG LCD tv
Pickled! You did right by checking the cables, the tv inputs and as well the output on the blue ray...even by replacing the blue ray. Which leads to a problem within the tv monitor. I can only guess there is something in the software of the tv that is causing the problem. I can only suggest two options. If can connect the tv to a network via CAT5 cable, you can do a frimware update to the tv. Sort of like a software update. If it is not available, try to swap the HDMI cable for the 5 RCA component video. It will still carry HD signal, just not as crisp as the HDMI. I would be floored if the same thing happened with the component cable.
Posted on Jun 30, 2010
joeymille916
  • 143 Answers
SOURCE: I'm staying at a Hotel in Atlanta that has 42 inch
I would call the front desk. They usually have a maintenance person who can help you with the connection. If the TV HDMI port is not functioning, they may be able to swap tv's or move you to another room! Good luck!
Posted on Oct 09, 2010
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
LG tv model 47LK520 has audio but no picture screen is grey. what is the problem?
Most likely your input button needs to be on a different input , if you have cable on HDMI #1 and a dvd player on HDMI#2 make shure your input button on your remote is on the right input ...also double check your HDMI cables that they are working because I have had cases where they go bad ! hope this helps Sincerely Glenn
Sep 02, 2014 | LG 47LK520 47 inch LCD HDTV 1080p 120Hz
How to connect laptop to LG 65LM 2500-TA
that" easy thing. first you need to check both of them --- lcd tv &laptop what kind connection have ? hdmi ? vga? rca? to find out which one. then you use one side connect to lcd tv . another side connect to laptop. & you need to sellect which one input for lcd tv. that" s it . good luck!
Sep 07, 2012 | LG 65LM6200 65 Inch 3D 1080p 120Hz Smart...
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
How do you change tv from 1080i to 1080p lg42lf2500 lg 42inch lcd tv thanks.
Not sure about your exact model, but for most HDTVs, you cannot set the resolution in the TV itself, the TV will automatically adjust to whatever signal is sent to it.
Note that Many HDTVs cannot do 1080p over component video inputs, only HDMI. Also, check for firmware updates for your TV, as manufacturers seem to be are often fixing bugs with things like HDMI input detection and so forth.
Oct 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
LG 55LH85 LCD TV Logo
65 people viewed this question
Computer Repairing
Computer Repairing
