Question about LG 42LG70 42 in. LCD HDTV
My lg 42 lg7000 will not power up, just the standby light is on..
My tv is stuck in standby mode and will not turn on.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
hi there, have the same kind of problem twice so far after was bought for me as x-mas present (although my viera isnt plasma, its an LCD TX-32LMD70A)..
I Pulled out the mains plug for about 10-20 seconds and then plugged back in (power button at top was pushed in, in the on position, so when the power was on, the tv just goes straight on). It then worked.
i would however like to know why this happens ( i really hope this isnt a hardware problem, as like many others... its only months old!!)
hope this helps
Posted on Apr 27, 2008
  • 86 Answers
SOURCE: My 42"LG 50 TV will not turn on
One important step to see if you are having an internal problem is to perform a power drain.
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this does not work but you are still seeing a LED lit up, there is probably a problem between the TV's power supply and the mainboard and service maybe required.
Posted on Oct 14, 2008
  • 1039 Answers
SOURCE: LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Posted on Nov 01, 2009
Testimonial: "cheers man thats what it was."
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
SOURCE: 42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Posted on Mar 17, 2010
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
How can I fix my 42' lg it is stuck in standby mode.
I had the same issue with my 47' LG. If it's under warranty just have someone look at it. Mine wasn't so I took off the back panel, checked the power supply for the correct voltages coming out, which were unfortunately were correct. Which only left the main PCB, which was more expensive than a new TV and could only be installed by a "technician." However, the blinks could be a fault code. Here's the link to my question. have 47 LG LCD TV 47LD450 AU and when try to turn it on the red LED...
Jun 17, 2014 | LG 47LD450 47 in. TV
When you switch on the tv it goes to standby mode, and when you press standby it turns on to a orange light then goes back to a red light, any idea whay this is happening ....
My Westinghouse LCD tv has the same lights on it It goes orange or red when there is no signal from that source... or while it is calibrating itself to the new frequency etc.
Oct 19, 2013 | LG 42PM3MV 42 in. PLASMA TV
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Mar 26, 2010 | LG 42PC3D 42 in. Plasma Television
LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Nov 28, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 42LG70 42 in. LCD HDTV Logo
464 people viewed this question
Computer Repairing
Computer Repairing
