Question about Microwave Ovens
How do you replace the display pcb in French Door LG Refrigerator, modle LFC21760ST? I need to replace the display pcb, but couldn't figure out how to get the old one out.
  • 4 more comments
  • mobiletec486 Apr 24, 2010
    That diagram is not going to be any help. I was able to pull out the lights and display - 2 screws and the rest of the fasteners were just plastic tabs. Anway, I was able to get that out. The lights and display come out as one unit. What I couldn't figure out was how to remove the display pcb from this unit. It's wedged in up against the touch pad. I could not figure out how to pull the pcb away from the touchpad. I tried a little pressure with a small screwdriver around the seam between touch pad and display pcb and there seems to be three points along the touchpad that are molded to the bracing that the display pcb snaps into. I don't know if it is molded, but it certainly wouldn't snap away and if I applied more pressure I think something will break. Any other ideas? It has to come out and away somehow, because I able to order and receive just the display pcb.
  • mobiletec486 Apr 25, 2010
    I don't have pics. The pcb itself does mount in by plastic tabs. That's not the issue. The problem is the orientation of how the pcb sits down in a "hollow" right up against the touch pad. I can release all the plastic tabs securing the pcb, but there is not enough room to move the pcb away from the touch pad and raise the board out of the hollow it sits in. I'm hoping you "FixYa" folks know the trick to get it out. Please help, the customer is waiting.
    I think what you are refering to as the "faceplate" is the key. I refere to the faceplate as the touchpad itself, and directly behind the touchpad is the display pcb. I need to get this touchpad out of the way, but can't figure out how, without doing damage. I ordered and rcvd the display pcb so there must/has to be a way to replace it.
  • mobiletec486 Apr 26, 2010
    No one has been able to help me yet. See the question and answer trail below. I'm trying to swap out a display pcb in an LG refridgerator.
    Apr 24, 2010 - That diagram is not going to be any help. I was able to pull out the lights and display - 2 screws and the rest of the fasteners were just plastic tabs. Anway, I was able to get that out. The lights and display come out as one unit. What I couldn't figure out was how to remove the display pcb from this unit. It's wedged in up against the touch pad. I could not figure out how to pull the pcb away from the touchpad. I tried a little pressure with a small screwdriver around the seam between touch pad and display pcb and there seems to be three points along the touchpad that are molded to the bracing that the display pcb snaps into. I don't know if it is molded, but it certainly wouldn't snap away and if I applied more pressure I think something will break. Any other ideas? It has to come out and away somehow, because I able to order and receive just the display pcb.
    Apr 25, 2010 - I don't have pics. The pcb itself does mount in by plastic tabs. That's not the issue. The problem is the orientation of how the pcb sits down in a "hollow" right up against the touch pad. I can release all the plastic tabs securing the pcb, but there is not enough room to move the pcb away from the touch pad and raise the board out of the hollow it sits in. I'm hoping you "FixYa" folks know the trick to get it out. Please help, the customer is waiting.
    Apr 25, 2010 - I think what you are refering to as the "faceplate" is the key. I refere to the faceplate as the touchpad itself, and directly behind the touchpad is the display pcb. I need to get this touchpad out of the way, but can't figure out how, without doing damage. I ordered and rcvd the display pcb so there must/has to be a way to replace it
    I called and spoke to LG support. They tell me there are two hidden screws behind the touchpad and the touchpad is like a decal that has to be peeled off to access the two screws. Thing is, there doesn't appear to be a part number so I can order a new touchpad/decal.
  • mobiletec486 Apr 27, 2010
    The manual is appreciated, but it's for and LFX model. I'm working on an LFC. The display in the LFX is notthing like the display in the LFC. Do you have a manual for LFC models?
  • 821 Answers
Hello,you can kindly call lg on their customer service desk to help you with the fixing if you still have warranty with them,simply because this requires an expert touch/fixing so as not to compound the fault.....
1300 54 2273
wish you good luck,or you can also call the number on your receipt of purchase or manuals..
take care.
Posted on Apr 27, 2010
  • 8,220 Answers
  • Dan Webster
    Dan Webster Apr 27, 2010
    I have the LG video training film but it is too fugging big.
  • Dan Webster
    Use the part numbers in back of the manual and get LG parts HERE
    President:
  • 1,070 Answers
Helloo,
HereYou will Get Complete Troubleshooting Guide for YourRefrigerator
DOWNLOAD it.....(Choose free Download)
Hope this Help you..You may Feel Free ContactMe....Thanks for Contacting FixYa...
Posted on Apr 26, 2010
    Guru:
  • 415 Answers
It appears the mounts are located on the 4 corners of the board. The mounts are either screw and/or combination of plastic mounts. The plastic mounts will have tabs that need to be squeezed in to allow the board to pull up off of the mounts. Any problems, can you send a close-up picture of the old board?
I'll look forward to hearing back from you. :-)
Posted on Apr 25, 2010
  • laura Newman Apr 25, 2010
    Are the components completely removed from the refrigerator? Some boards have have to be removed from the faceplate to access the screws that hold the two boards together.
    Is it possible to send some close-up pictures for me to review?
  • 4,070 Answers
Pcb of microwave oven not working
you need to replace the PCB see the diagram attached. go to
www.repairclinic.com and get it
Jul 28, 2013 | LG Microwave Ovens
I just purchased a Samsung French Door Refrigerator...how do I get rid of the plastic odor?...I've put baking soda in the refrigerator and the freezer but the odor persists.
You can try activated charcoal to absorb the plastic odor. You'll find charcoal in the aquarium section of your ""big box" stores. Depending on how it's packaged, you might have to cut a **** in the package to expose the charcoal. You DO NOT want to use Barbecue charcoal! You can also wipe down the entire interior with a baking soda solution and then rinse.We had the same problem with our Samsung French Door and it was gone within a few days once we began filling it with food and leftovers!
I hope this helps. If it does, please come back to Fixya and rate my advice.
Aug 07, 2011 | Samsung Microwave Ovens
LG Microvave just stopped all at once as if the power went out. Nothing will respond. I checked the outlet is fine.
you may have blown a fuse if there is no power display...the fuse unfortunately is located in control panel... it usually is either a 15 amp or 20 amp fuse... do not put a larger one in or a smaller. to test the fuse if you cant visible see it is bad you will need to ohm out and should get continuity ...if the fuse is good and you have no display most likely the pcb or board is bad.... good luck
Jan 02, 2011 | LG LMV2053 Microwave Oven
Turn table does not turn when heating. Interior light does not come on during cooking, works fine when door is opens.
some microwave is have PCB control if pcs is shorted some parts light bult,fan or syncronus motor is on mode we need to replace the pcb but some problem is only is micro switch,if mocro swict is rusty or corroded that the time not working the turn table,but you said every time open the door the ligth is ok,if the turn table also running during open door have problem in your pcb board that we need for replacement,but check the price of parts and make it desicion if you want to repair or buy a new one if your unit is very old.
Dec 28, 2010 | Microwave Ovens
My modle # mmv4205aab lost all power, no display, no nothing. thank you
Hello- Unplug, open door, and remove screw holding display panel. Be careful, some wires may need to be unplugged. 20a fuse should be visible. If this fuse is bad- replace and address any power supply issues, such as age of wiring or circuit load-(other stuff plugged in) Hope this helps-ED
Mar 01, 2010 | Maytag Microwave Ovens
NN-A774SBBPQ Invertor & Cat-Clean model.
no 3rd fuse as far as i know just the two on the mains pcb and the plug i would test all three fuses again but if the short has gone back up to the control panel them that might be why its not coming back on if it has blown the control pcb it will show up as ablack mark on the pcb sorry cant be nore help its the sort of thing i would need to see as it could be a door micro switch as well gd luck dont forget to unplug the unit
Oct 05, 2009 | Panasonic Microwave Ovens
Display scrambled on my model # LMVM2055ST
HI. this LCD is attached to the PWB assembly board. Unfortunately, this lcd is not sold separately and, you will need to replace the whole PWB assembly in order to fix this issue.This is actually a pwb(pcb) assembly failure.
CLICK HERE TO ORDER YOUR NEW PWB ASSEMBLY(LCD)
Jun 04, 2009 | LG Microwave Ovens
Need manule for modle no. mh-1355h
Many LG/Goldstar manuals can be downloaded here.
Otherwise, for Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Aug 19, 2008 | LG Microwave Ovens
Door outer plastic plate slide down an inch from the top
You would probably need a service manual, for which you can contact LG at 1-800-243-0000 or http://us.lgservice.com
Or locate a local servicer:
http://us.lgservice.com/gcsc/b2c/hpi/main
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Nov 19, 2007 | LG LMV1645 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
