Question about Creative Labs ZEN Vision:M Digital Media Player
Dead Creative Zen M
My Creative is completely dead. It doesn't turn on. Reset does nothing. Computer can't detect it either. Some people have got a flashing blue light but mine doesn't even do that! Has the battery completely died on me?
Please help. My creative lab version M is dead (I left it alone for several months), I dont even get a blue light. I left it plugged in the wall over night and it's still not turning on.
    Genius:
  • 3,587 Answers
Does this unit run without battery at all? could be the internal charger is truly unhappy.
as to the battery life issues. there is a rule of thumb. temperature and storage will decay the internal chemistry of any rechargeable battery. The most effective means of making a battery life extend, is to actually run it through short charge recharge cycles, with a small current requirement(which means when the system is in idle, not when it's on full load)..
so, if your battery is unhappy, it's more likely due to the decay effect of the storage and temperature situation.
now, can it be recovered.
possibly..but you may be looking at a recharge cycle along these lines.
Recharge time, is usually 5-7 times the discharge time. So calculating this..if you want to trickle charge your dead and deceased battery, you may need to take it off the power source you have, and have it trickle charged with a charging device.
the energy issues inside the tired battery material, makes it incumbent to NOT fast charge this battery.
your chances of success?
I'd give it 1 in 4 to be recharged.
Posted on Mar 23, 2008
  • Creative Labs Master
  • 19,396 Answers
If your zen does not turn on or show any sign of life when connected to the adapter, then must be the charger that is not working, not the battery. In any case not the battery alone. Here is the charger for $6.
To Ensure that the charger, and/or the battery is faulty you can use tester , one under $10 will do the job. Use the tester to check that power is ok on charger connector. If this one is ok ckeck battery contacts inside the Zen battery box, while zen is connected to power.
Regards
  • Ginko
    Ginko Mar 23, 2008
    Yes, the Zen run without battery
    Brigadier General:
  • 3,614 Answers
In my add to :pincer, maklean, early1234
The working life of a battery pack usually exceeds 500 to 600 complete charge/discharge cycles. If you run your laptop using a mix of AC and battery power, the battery will typically last up to three years—maybe longer. Always refer to the laptop’s documentation for specific battery life and replacement recommendations.
As a rechargeable battery wears out, its charge time decreases. For example, the new battery that used to be able to power your laptop for six hours may now only provide three to four hours of running time.
You can extend the working life of your battery pack by reducing the number of charge cycles.
Regards
  • 871 Answers
Try to replace the battery for that my friend. being unused for several months then suddenly charging overnyt would really do damage that we dont think is conceiveable.
anyway, to change the batteries for that, here is a very helpful video on how to replace the battery for your ZEN player.
a new battery costs around 30 dollars.
just do be careful not do damage your player while changing the battery ok.
hope this helps
    Genius:
  • 1,665 Answers
You must buy a new battery i think
    Master:
  • 377 Answers
Check first the battery... it could be there.
My creative zen won't turn on it's vision m 30 gb and when you plug it in all it dose is flash It doesn't pop up or even say anything in my computer PLEASE HELP
I am unable to reset my ZEN Vision M player. It will not even connect with my computer and the battery is completely dead. Is there a solution?
Jul 03, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Jun 10, 2009 | Creative Labs Zen Stone Plus MP3 Player
Zen v conection problem
OK ALL IS WELL JUST..Allow unit to run dead.recharge battery.turn on and push reset(smallpaper clip in reset hole).turn off and back on .should now work.if notformat and download new soft ware athttp://support.creative.com/kb/ShowArticle.aspx?sid=8451.RICHARDM69
Aug 31, 2008 | Creative Labs Zen Neeon MP3 Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen stone mp3 player not switching on
Mine was also completely dead, with the reset doing nothing! I held the vol+ and the Play button at the same time and it was good to go. Holding just the play button or the vol+ button didnt acheive anything. But as I held both together, It came back to life instantly and I havent had any problems with it (for a week so far).
May 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen v plus 4GB
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Oct 24, 2007 | Creative Labs ZEN V Plus MP3 Player
Not getting turned on
Zen V is dead
Aug 21, 2007 | Creative Labs ZEN V Plus MP3 Player
Zen Neeon frozen completely
Leave it alone for a while, then try reinstalling the Zen Program, then plug it in, then rest it, then try to switch it on. It worked for me
Jul 27, 2007 | Creative Labs Zen Neeon MP3 Player
Creative Vplus hangs while charging
Zen V is dead
May 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
148 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
