Question about Zhone (6218-I2-200) Router
I can not connect to my IPOD - Zhone (6218-I2-200) Router
    President:
  • 1,768 Answers
You will need to connect the I Pod to the computer and have I Tunes installed.
Posted on Apr 26, 2010
Ipod is disabled and cannot connect to itunes as have new laptop
How to restore iPod
  1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
  2. Download and install the latest version of iTunes if necessary.
  3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  6. Click Restore.
  7. If you are using a Mac, you will be asked to enter an administrator's name and password.
  8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
    • Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
    Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
  10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
Apr 02, 2011 | Apple iPod touch
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
Tip
How to connect an iPod to a TV
<p>The iPod is a very capable media player personal, but sometimes that tiny screen just does not cut it. Fortunately for owners of iPod, Apple allows users to connect their devices to a TV, so that the videos from your iPod to transmit to the screen. For this connection, iPod owners to buy an extra TV out cable, which is sold in most electronic stores. <br /> <p><br /> <p>1. Buy a cable TV output compatible. Apple sells three TV-out cables, iPod composite cable, composite cable Apple and the Apple Component Cable. See the References section for an iPod TV out cable compatibility list to ensure that you have purchased the correct cable. <br /> <p><br /> <p>2. Connect your iPod to TV out cable TV. Depending on the output cable TV you bought, the cable connects the input of the composite or component input on your TV. Each entry is color coded to the appropriate plug-ins to handle. <br /> <p><br /> <p>3. Connect the other end of the cable to your iPod. The cable consists iPod is connected to the headset connector iPod, Apple, while the other two-plug cables into the wall socket. <br /> <p><br /> <p>4. Turn off the TV mode on your iPod through the opening of "Video Settings" from the "Videos" menu on your iPod and change "TV Out" to "On." <br />
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance my ipod is not charged, when connected to a computer
hello!
if your IPod touch is not connected to itunes, please try the ff:
Check the iPod touch Display
-- When you connect iPod touch to your computer, the iPod touch should display an image or message on the display
-- If you do not see any image, check some basic troubleshooting here: http://support.apple.com/kb/HT1737
-- If you see a message on the screen, this indicates that the iPod touch does not have sufficient battery charge to operate and will need to be charged for several minutes before it can be recognized in iTunes.
Verify Windows PC System Requirements
--iPod touch requires iTunes 7.4 or later
Check USB Connections
-- iPod touch requires USB 2.0 to function properly
-- Try connecting iPod touch to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPod touch to your keyboard's USB ports is not recommended.
Restart your PC
-- In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
Verify iPod touch Driver/Service Installation
-- iPod touch requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPod touch the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service.
May 08, 2008 | Apple iPod touch
Tip
How to connect an iPod to my Bose Radio
<p>The manufacturer offers two radios Bose iPod connection kit to connect an iPod to the radio. You can purchase the kit to connect the wave or acoustic wave connect kit. Both kits come with a USB audio connection, an iPod dock for iPod, a battery that plugs into the wall and a remote control to use the iPod while in dock. Download all the upgrades to your iPod through Apple's website before connecting a Bose radio. <br /> <p><br /> <p>1. Connect one end of the audio cable is included with the connection kit for iPod "Aux In" on the back of the Bose radio. <br /> <p><br /> <p>2. Connect the other end of the audio cable to the "Audio Out" on the back of the iPod dock. <br /> <p><br /> <p>3. Connect the adapter to an outlet connection kit. Connect the other end of the battery to the "DC Power" on the back of the iPod dock. <br /> <p><br /> <p>4. Set the iPod dock on the right side of the face of Bose radio out. Align the IR sensor on the front of the iPod dock with the IR sensor on the front of the Bose radio. <br /> <p><br /> <p>5. Place the iPod firmly in iPod dock. Point the remote at the IR sensor, iPod dock. Press the "iPod" for the iPod <br />
Ipod battery
Hi all,
Since you guys hav tried many option to charge the ipod... try this out by connecting it ot USB port at the rear of your desktop computer..
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
also try this out
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Nov 30, 2007 | Apple iPod mini 2nd generation MP3 Player
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
Sep 28, 2005 | Apple iPod nano
Zhone (6218-I2-200) Router Logo
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
