Question about Vizio L32 32 in. LCD HDTV
Vazio p 42hdtv10a when plug relay click no power all power voltage ok . only yellow led is on any idea thanks
  • 431 Answers
The problem probably lies in the 5v rail start up a common fault with these sets , you should be able to get a repair kit modification pack from your local component suppliers . It will also usually come with a little diagram of which components to replace , I think it is 5 Radial Electrolytic Capacitors ranging from 33uf at 50v to 10 uf at 10v and two voltage control ic's one is an smp but is listed as an IC . you can probably find a schematic of this circuit at http://www.eserviceinfo.com
If your not completely electronic savy I would suggest maybe an engineer should deal with this one . Alternately a new PSU unit that merely plugs straight in can be purchased off the net , there are many outlets willing to supply for all types of sets . Hope this is of help to you Regards Vortash
Posted on Apr 24, 2010
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
I have a reebok crosswalk rt 5.0 treadmill. I can calibrate the incline and it goes up and down. however when you press the button to raise the incline the incline number will change but the machine does...
Step 1:
see this details and proceed according. God bless you
LED.
Step 2:
This the board LED, who control the DC to +12vdc) then the +12V LED lights.
LED.
operating properly.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP for elevation Motor. You must clean contact of the Relay with Special Spray(Radio Schack).
With this you must fix it.
Jan 07, 2013 | Reebok Exercise & Fitness
My new visions t9550 treadmill will not calibrate. it completes the speed calibration but treadmill will not elivate therefor fails calibration. what do i do?
Step 1:
follow this steps for troubleshooting and fix it. God bless you
LED.
Step 2:
LED.
operating properly.
Step 3:
Try this again. and fix it.b) LUBE the gear motor, shaft and turn the POT a little and see if the motor get RPM.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in).
Jan 07, 2013 | Vision Fitness T9550 Folding Treadmill
Initial calibration keeps failing. the treadmill will not elivate
Step 1:
please see this test and fix it. God bless you
Step 2:
LED.
LED.
operating properly.
Step 3:
please lube the elevation motor, shaft, and gear, and adjust the POT for RPM, and see what happen. see the diagram + block diagram attached for troubleshooting and fix it.
God bless you
Toshiba Laptop no longer charges battery
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 07, 2012 | Toshiba Satellite L555DS7930 Notebook
Hi, I have a 5-year Panasonic TH-42PZ700E plasma and a week ago it got broken. When I tried to power it up with the remote, it just didn't do anything. Tried the power button with the same...
Hi from your description it sounds like your TV is turning on since the red light stays on and it's not blinking. In that case I would say that since your TV is on but you are not geting a picture then one of your Zustain boards is bad. the first thing I would do is to check the fuses since you said you already did that and they are fine you can check that their is high voltage getting to your Zustain board. Their is a sticker on the screen that tells you how much voltage they should be geting. Usually about 220 volts. If you are getting voltage to both bords you can check to see if the heat sinks are getting how. They are supposed to be hot so if they are not that board is bad. If all else fails you can try replacing both boards. To order parts you have to get the part numbers from the actual parts. You can get parts from www.interliquidparts.com
Jun 13, 2011 | Televison & Video
Pana TH-52PWD8UK. No picture, flashing red LED on front panel
Thanks for the quick answer. I purchased the set in 2005 and it lives outside under an overhang on my patio in humid South Florida. Unfortunately, I couldnt count the red flashes before it went completely dead. Think it was 4or 5. This would correspond with a possible fuse failure on the Power supply. I bought the online service manual, I just wish I knew what to do with it!! The fuses both seem to check out ok on a continuity check. any ideas? Thanks, Charlie
Dec 05, 2009 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
Standby LED stays red.
This can be a combination of things. The main power supply may have failed, or there is a short putting it in to protect mode. It is also possible that the back plane supply and or lamps have failed.
Jerry G.
May 13, 2008 | Philips 32PF9964 32 in. Television
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
Vizio L32 32 in. LCD HDTV Logo
99 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
