Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Stalling while mowing
While mowing my riding lawn mower will begin to hesitate. Most of the time it will begin to move again after a second or two. However, it will occassionaly shut off. What could be the issues?
    Problem Solver:
  • 18 Answers
There is verfy possibly a fuel restiction in the carb. Many times the particles in the carb float bowl are restricting the fuel flow past the needle valve. I would advise adding some carb cleaner to your gasoline. The other possibility could be a loose carb or carb gasket which would cause a loss of suction through the carb and this would decrease the fuel draw. Soooo if the carb float bowl is the suspect. FIRST you will need to turn off the fuel supply. If no valve is avail, find a bolt or some object that will work to plug the fuel hose when it is removed from the carb you will need to grab a small bowl to catch the fuel when you remove the bolt holding the float bowl. Carefully and I mean gently remove the bowl (sometimes the bowl is slightly sticking and needs a slight bump)and see that the operation of the float moves up and down with no restriction of movement. See if there is any dirt in the bowl. wipe the bowl inside to remove dirt. Carefully reassemble. MAKE SURE no fuel is leaking or spills are in the area. Fire on the outside of the engine is not the prefered method!!!.
Posted on Apr 25, 2010
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
I bought a john deere riding mower less than a year ago. i used it last season without any problems. I think the last time i used it, was in august 2010. winter came about, the grass wasn't growing, so...
First, I've had a motorcycle for almost 50 years and have never drained the gas. At one point it was not used for 3 years. It started, I added gas and it ran fine.
Second, next time you are running the machine and it begins to stall, immediately loosen the gas cap. If it starts to run good again, drill out the air vents on the cap.
Gary
Mar 09, 2011 | Garden
Hesitation while mowing
Check your hydraulic fluid level in you transmission area, make sure all belts are tight and in good condition.
Apr 07, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engins starts and runs when mowing will backfire and stall.
I am not sure what time of lawn mower this is, but if the blade is directly tied to the motor, usually the belt will just slip if not, but if this is directly connected to motor, it might have jumped timing. If this is not the case, inspect under the mower deck, and determine if there is something jamming the blades against the deck or if their is something bound around the blade, this can cause more strain on the motor, which could result in the symptoms your experiencing.
Aug 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troy built lawn tractor keeps stalling out while mowing lawn. It starts up again, but mowes for a couple of minutes then stalls out.
Have you checked your air filter..it sounds like it could be dirty and needs replacing..if this dont help..just comment back and i will get it..and i will help you further..Keith
Jul 04, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
282 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
