Question about Craftsman 24 Hp 48" Deck Yard Tractor
Hydrostatic drive seems to be weak. belt to motor isn't broke. seems to slip more and more as you go. up hill pulling of lawn rake nearly impossible.
    Problem Solver:
  • 6 Answers
Try using the heel of your shoe and pulling back on the brake/clutch pedal and see if it helps. Cronic problem with these mowers-Belt slipping when linkage get a little wear-with no solution???
Posted on Apr 27, 2010
  • rickhan Jun 10, 2011
    Pulling back on the brake pedal definitely tightens the belt. Looking closely, there is nothing but the big spring tensioning the belt.. Don't see how loose or worn linkage could affect anything there.
    I replace the spring, both front and back drive pulleys, and the belt. It worked OK for a while, but after an hours use, the belt was slipping again. I was thinking of drilling a new hole in the frame and stretching the spring another inch or two.
  • 110 Answers
Sounds like the trans-axle is going bad. Belt tension is maintained by a rather large spring so unless the spring is broken this is unlikely. There are no serviceable components on the trans-axle the entire unit needs to be replaces. Easy but expensive job. These are the things that the Sears service plans are for.
Posted on Oct 23, 2010
Hydrostat slips going up hilland you have to keep feathering the pedal to get it to engage
When you say Hydrostat, I automatically think lawn tractop. If this is correct, then the reason it is slipping and just won't go is that your main drive belt is worn and slipping and won't pull. Replace the main drive belt and make sure the belt tensioner is fine and your done.
Jun 13, 2017 | Cars & Trucks
Mower wont cut going up hill
there should be two drive belts. they should be replaced both at the same time. if one is wore so is the other one. use the correct belt, from a lawn mower parts store.
Aug 26, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
Hydrostatic trans getting weak going forward. Won't lug engine and have to go to low gear to pull hills it used to pull in B. Reverse is still strong. 380 hours, have change filter, oil looks good
The big pulley on top of the hydro axle is driven by a rubber belt.
V Drive belts pull from the two sides of the belt, as they wear down the bottom of the belt gets lower in the pulley making it loose and narrower then original. There is a idler pulley mounted on a arm with a big spring that pulls it tight to make belt not slip
Mar 14, 2016 | Garden
How to change dive pulley for 944602660?
This is likely due to a worn and slipping belt. Replacing the belt should solve the problem
Aug 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Hydrostatic want pull hill
Either the belt is slipping in the pulleys ( replace belt ) or the hydro unit has internal wear, if this is the case as the unit gets hotter the issue will become worse due to the oil getting thinner and leaking internally, this would mean a hydro rebuild, or replacement unit
Jul 07, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Sep 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My L118 John Deere Lawn mower doesn't want to go up hills or even move after it gets hot. what is the problem?
check drive belt tension when m/c is off.remember OFF! if too loose,refer to manual.
Jul 21, 2009 | Garden
I have a walk behind mower. The drive belt broke and I replaced it and now it wont pull itself. The wheels still spin if I lift it up but when I set it down it wont go anywhere
you must have a belt tensioner somewhere. Have a look near your belt pully or a idler pully that has an adjustment screw where you can tighten your belt to give grip. It appears the weight of the mower is causing the belt to slip hence it no moving because your belt /belts are slipping
Jul 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
1,025 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
