Question about Maytag Neptune FAV6800AW Top Load Washer
Our top load washer washes a couple of loads fine
Our top load washer washes a couple of loads fine but then it stops on the rinse cycle and nothing will work for about 15 minutes then I turn the timer back on and it works fine. I was wondering where the breaker or reset button is located at?
  • 64 Answers
Sounds like the thermal breaker inside the motor is heating up and triping it resets when it cools either the motor it's self is geting hot or something is causing it to over heat. Just a guess hope this helps
Posted on Apr 24, 2010
Problem with spin in rinse cycle
Yeah that is a lid switch problem. I have a page I compiled that shows how to fix this easily: HERE
Jan 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not spin
is the door lock lit make sure the door is closed all the way make sure the dispenser door is closed all the way their is a magnetic switch in it that will not let the washer spin if its not closed it also will not spin a small load try adding a couple of items let me know if this does it or not
Jan 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Washer stops after wash cycle
the timer is bad you could try cleaning the points by taking it apart very hard to do though
Aug 27, 2007 | Kenmore 23822 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
118 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
