Question about Maytag Atlantis MAV6000 Top Load Washer
Water will not spin out
Washer fills and washes the clothes, bu will not spin out the excess water
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
How do I get excess soap out of my washer so that it will drain?
Take the hose from the back of the washer and find something to drain the excess water in. Be careful, the water comes out fast so, let the hose release some of the water and then quickly raise the hose so it does not get water everywhere. Do this until there is no water in the machine.
Then try using it again.
May 15, 2017 | Kenmore Washing Machines
Washer adds water whilst extracting
The washer will add water in the rinse/pin cycle even while it is pumping out. This is to give the clothes a wash while spinning to remove excess soap suds. Could this be your problem
May 27, 2013 | Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
Cold fill washing machines
If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
Jan 23, 2010 | Washing Machines
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Spin cycle doesn't work
the motor coupling is bad it is between the motor and transmission
Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Atlantis MAV6000 Top Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
