Question about Dell E173FP 17" LCD Flat Panel Monitor
Lines and shadows across the screen
We have a dell monitor and the Vista operating system, I am not sure what the problem is, but we have these weird shadows and line across the monitor. I do a lot with pictures and it interferes in my editing.
  • 11,361 Answers
I would try it on another PC first, also check the VGA cable connectors at both ends. It can be that the filter caps in the power supply are failing inside the monitor.
If you decide to open up the monitor, please look through my albums so you will have some idead what to look for inside.
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 25, 2010
Shadows on monitior
This sometimes occurs when the machine gets too hot. If your graphics card is too hot, its performance will suffer. Check the fan speeds/ temperatures and see if that helps.
Dec 12, 2012 | Samsung 22" TFT SYNCMASTER P2250 LCD...
After 15 minutes horizantal black lines appear on moniter
Welcome to Fixya.
Few of the top reasons for causing these "lines" running across the screen are :
  1. Corrupted video driver
  2. Changes in hardware configuration (display)
  3. Monitor issue (hardware)
In order to determine if it's hardware/software issue, all you need to do is to boot to BIOS and check if the problem replicates. Depending on system, you can go to the BIOS screen by tapping "F2" or "DEL" key repeatedly as soon as you turn on the computer until you see a different screen.
If the problem is present while in BIOS, then definitely the monitor needs to be repaired by an authorized repair center. Otherwise, video driver update or Operating system re-install can resolve this problem.
Here's DELL's support site for more information :
Dell support
Thanks for using Fixya
Apr 12, 2011 | Dell Dimension 4500 + Lexmark Z35 Printer...
My Dell monitor developed a thin, dark line horizontally across the screen. Within three months, a second line appeared. I can view the screen, but must look above or below the lines at times. Any idea...
this occurs very commonly in all LCD monitors... this is because each and every cells in the LCD monitor are energized by the vertical and horizontal electric fields placed around the frame of the monitor... if a particular field does not gives the power to the associated cells to it, then the entire line of cells will not operate and together they looks like a single line...This is what happened in your case...
have a look at my tips for replacing the LCD screens on monitors, by clicking here....
Aug 11, 2010 | Dell Audio Players & Recorders
I have 7 different hortizontal lines appearing
Try changing the VGA cable between the computer and monitor.
If that does not fix it, try a different monitor.
When you say "different operating systems" are they on the same physical computer/graphics card? If so, and the cable/monitor swap suggested above does not change any thing, then it is probably the Graphics card, or possibly something in the system (bad power supply?) that is injecting noise on the bus to the graphics card.
If none of the above. Bad Monitor.
Sep 16, 2009 | Dell Computers & Internet
Horizontal ghost lines across screen
Seems that it is an issue with your video card, Please update Driver for Video card and it that does not help, it is the time to replace the Video card.
You can get your driver from support.dell.com and please enter your service tag to download the driver
May 25, 2009 | Dell M781S Monitor
Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Jan 29, 2009 | Dell P1130 21" CRT Monitor
Shadow images on monitor
if it is vista it is normal otherwise I would need more info operating system video card monitor etc.
Dec 03, 2008 | Computers & Internet
Parallel shadows across the screen
Hi, what type of the monitor, LCDs or CRTs???? Also, will the shadows being shown at the same spots or at different spots at different time?? it could help to narrow the problem, post it on more detail if possible.
Nov 04, 2008 | Computers & Internet
Problem with shadows showing on monitor
LCD Monitor Shadow Effect
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this is very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
Dell E173FP 17" LCD Flat Panel Monitor Logo
152 people viewed this question
Alun Cox
