Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
I have a weedeater featherlite - won't stay running. I've cleaned the air filter and replaced the spark plug. It will start and run for a couple of seconds then shuts off.
SOURCE: Featherlite will not start
Suggest , Clean Spark plug with Gas and wire brush.... drain all gas, add new gas with correct gas:oil mixture..... spray Gumout/Carb cleaner in air intake and spark plug hole.. these are the easy solutions to try.. good luck -Doug
Posted on Nov 24, 2008
  • 71 Answers
SOURCE: Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
Posted on May 02, 2009
bulldogchief
  • 388 Answers
SOURCE: weedeater will not start. was running, shut it off
Pull the spark plug after pushing the primer bulb and cranking a few times...if the plug is "wet" (indicating fuel is present in the cylinder) then the next step will be checking the compression...compression should read above 90psi (preferrably 100-125psi)...if compression is below 90psi, the most likely culprit will be a stuck piston ring.
Posted on Sep 08, 2009
bbreton
  • 437 Answers
SOURCE: my new blower just won
When did you purchase it? If it is under a certain number of days, you may be able to return it. Other wise you will have to find a warranty repair center for that blower and get them to look at it under warranty. Make sure you have a copy of your receipt when you take it in to the shop. ** But make sure the shop does not get a diagnostic fee or handling fee because they are getting paid by the warranty company.** You should not have to pay a dime if it is under warranty.
Good Day.
Posted on Oct 07, 2009
  • 89 Answers
SOURCE: Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Posted on Nov 06, 2009
Testimonial: "Thanks for the help. The gas line was dessolving on the inside and getting into the carb. I replaced the gas line."
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Weedeater won't start
inside the carb there is a small screen. it is probably dirty. also the diaphragm may be stiff. go ahead and rebuild it. the kits are cheap and it should run like a new one. there are videos on you tube that show how to do this.
May 11, 2017 | Poulan Garden
I have a Poulan Prolink 150E weedeater. One day I was running it and it just stopped. I've changed the plug, thinking that was it, it wasn't. It's getting gas but not fire. Do you have any
If fuel is present and spark is good then it's air. Remove air filter and see if it starts. If so, it's time for a new one.
May 02, 2012 | Garden
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
My weedeater 150 mph starts hard and barely runs at full throttle. I put in new gas, plug, and clean air filter. Please help. John
One cause of such a symptom could be an obstructed exhaust. Make sure the outlet of the muffler is not obstructed (ex. dirt dobber nest), also check the exhaust port by removing the muffler.
Feb 16, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
One year old Poulan weedeater starts right up but will only run with choke about half way on. Warm it up that way but it does not run any better. New gas, new spark plug, clean air filter. The weedeater...
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater very hard starting or not starting at all
One of two solutions. But the only thing wrong is the carburetor. It needs cleaned or it needs a new carb. kit. If you need tips on how to clean, just let me know.
Jim
May 30, 2009 | Poulan Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
524 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
