Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Cdx platter doesnt spin ??? what parts could be the problem ?
    Problem Solver:
  • 17 Answers
2 possible causes:
Motor Controller PCB: http://ep.yimg.com/ca/I/yhst-15436568105612_2102_25839247
Or motor itself: http://ep.yimg.com/ca/I/yhst-15436568105612_2102_63389888
You may be able to visually tell if there is a smoked resistor on Controller board.
Posted on May 06, 2010
Wont spin
Hello Bella, This is a belt driven turntable. Most likely, your drive belt has fallen off. It may be too stretched to stay on. To check this, remove the rubber platter mat. There should be holes in the metal platter, which if you rotate it, you will see the belt and the motor pulley. Remove the metal platter by grasping the holes. It should lift off. When the platter is off, try to slip the belt over the inside flat part of the platter. It should be snug. If it just falls off, the belt needs to be replace. For more information or parts, please go to my website, AUDIOSERVICECLINIC.COM. You can contact me through the website, and we can take this issue further if need be.
Thank you, Dave
Audio Service Clinic
Apr 13, 2014 | Aiwa PX-E860 Turntable
Stanton t.80 Motor produces hum sound when holding the platter to cue. When platter is released the hum disappears. Also is a slight hum on start up. Have opened the turntable and all connections seem to...
Do you keep the platter at one place --> don't you let the platter spin and keep the record at. one place, you are know f.5;5,g your engine and parts.... buy suzuki slipmats and use the plastic rounds of plastic .... i thought by thud rumble too let your table spin when you hold the the platter, otherwise components get to hot
Aug 03, 2013 | Stanton Audio Players & Recorders
Technics sl 1210
you might try lifting the platter off and putting a drop or two of light machine oil on the spindle. cleaning the motor might help also.
Jun 27, 2013 | Audio Players & Recorders
The platter on my CDX is a bit lifted and wobbly. How can i fix that?
That is normal vinyl itself was never really straight and as for the platter it should have some give to it now if it looks like a bent rim on a bike then i would send it back but a little play is fine.
Apr 19, 2011 | Numark CDX Turntable
Turntable platter doesnt spin when you press start/stop
Is your turndable belt driven? If so replace the belt.
Jun 05, 2010 | Numark TTX Turntable
Numark cdx
have you checked the brake and start up settings they are the dials by the start and stop buttons it it is turned too far the platter will start up slow, you just trun to dial till you get the right start up speed you want
Jul 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Vestax cdx-05s
The problem is with the tiny grey switch that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Jun 24, 2008 | Vestax CDX-05 Turntable
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
137 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
