Question about Mitsubishi VS-50111 50" Rear Projection Television
Diagnostic code 23
My mitsubishi 50111 shut off while my autistic son was monkeying with it. The diagnostic code says 23. WHAT DO I DO NOW????
  • glorydays Mar 23, 2008
    yes, so what do I do about that? How do I fix the code 23 (horizontal deflection?)
  • Mitsubishi Master
  • 8,617 Answers
Loss of horizontal deflection is what code 23 means in that model.
Posted on Mar 23, 2008
  • Sonny Berry
    Sonny Berry Mar 24, 2008
    you will need to troubleshoot the deflection circuit. usually the horizontal and vertical outputs are first items to check followed by the regulator transistors.
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
VS-50111 and horizontal lines appear and shuts off
hello i have the service manual which i'll send for free along as you leave me a fair rating thanks
regards
shaun
May 31, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Mitsubishi VS-50111 50" Rear Projection...
I own a Mitsubishi HD 1080 series HD TV; MODEL#VS-50111. Recently the TV shut itself off after a few minutes of operation. I unplugged it and after a few hours, plugged it in and it came on for about 5...
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Oct 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
I posted a problem. Got a solution. It was on a Mitsubishi 50111 TV. Did the diagnostics and got a code 22 for Short Protect Circuit. Now what do I do? How do I find out if its too expensive to fix? ...
Call a good TV Tech and tell him the code.
He should replace Q9A55,ECG85-D9A29,5.6V ZENER-D9A28,ECG519-PC9A21,ECG3098.
This repair should not cost over $175.
Check with your local BBB before you decide on one.
Jul 29, 2009 | Televison & Video
Mitsubishi 50111
Run the diagnostics.
With the TV power cord plugged in, press the 'INPUT and 'MENU' buttons at the same time -- use the buttons on the front of the TV, NOT the buttons on the remote; a diagnostic Error Code Operational Check will begin, utilizing the 'POWER ON' LED (the green 'POWER ON' indicator light).
There will be a pattern of two sets of flashes, with a pause in bewteen flashes; this sequence of flashes will be repeated a total of five times.
The Error Code designations are listed below:
Error Code Description
12 No eror has occurred.
21 X-Ray Protect circuit.
22 Short Protect circuit.
23 Horizontal Deflection failure.
24 Vertical Deflection failure.
I hope this information helps.
Jun 17, 2009 | Mitsubishi VS-50111 50" Rear Projection...
How to figure out diagnostic code
wat is the code ???
is it Error code 2-3
if so check q5a01 and 03 thrue to q5a06
also replace T5a31 PN/340p216010
Jan 14, 2009 | Mitsubishi VS-50111 50" Rear Projection...
MY T.V. WONT TURN ON
this sounds like your flyback converter is burned out on the circut board....cheap part! but must be done by pro!
Dec 09, 2008 | Mitsubishi VS-50111 50" Rear Projection...
2002 Mitsubishi VS-50111 WIll Not Stay on
FIRST Check for open fuses F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF fuses are open then convergence output circuit would be your problem.
Dec 17, 2007 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
