Question about Dryers
I'm only getting cold air blowing out condenser
I'm only getting cold air blowing out my condenser dryer - please help new baby and loads a washin'......
    Passionate:
    Visited the website for 10 consecutive days.
    Champion:
  • 207 Answers
You need to call a techincian sound like your heater element when out are if this is a gas dryer your glow bar are your gas coil when out,sorry
Posted on Apr 25, 2010
A/c not blowing cold air
Does the blower motor work ? maybe a bad mode door actuator ! What make vehicle , model an year ? Manual or automatic HVAC system ?
Jul 13, 2015 | Cars & Trucks
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Water under dryer after use. cleaned exhaust lint in it was wet. should i insulate exhaust tubing. fsminatrea@yahoo.com
Hi
Dryer would be either leaking from vent or due to condensation. The vent may either be blocked. The water is coming from the clothes you have dried in the dryer and it has no where to go.
You need to dismantle the vent and clean it, replace it with new vent. The dryer may now be consuming more time to dry the same load of clothes. By correcting the venting problem you will solve the water problem and shorten your wash day and save on electricity as well.
Another issue is condensation which usually appears on the dryer vent pipe colder climates. As the warm air from the dryer is vented to the outside, it must be protected from the cold temperatures outside. If your dryer vent pipe is not properly insulated, the air that is being vented out will turn into water when it comes into contact with the cold pipe outside. This results in condensation and dripping water. To resolve this, you must insulate your dryer vent pipe along its entire length. This will ensure that the hot air from the dryer does not undergo temperature fluctuations, and no water will leak into the vent pipe. Hope this helps... Please post back if you need more information.
Danile
Dec 27, 2010 | Maytag Dryers
My zanussi xc6 condenser dryer is blowing cold air,please help.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Zanussi Dryers
It blows air but it is cold it does not get hot had thermail limi
Depending on the type and make or model of dryer check drum turns,filters are not blocked or condenser is not blocked.then if all ok it could be the safety thermostats or the heating element.
Hope this helps.
May 10, 2010 | Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Dryer doesn't dry clothes, doesn't start right after Wash
If the machine is brand new, I imagine all you want to do is check you're using the machine correctly before you claim on the warranty. Trouble is, the design of this machine is so weird, and the instructions so poor that it's easy to get it wrong. So far as I can make out from this distance, you need to have all of: Spin Cancel: Out Half Load: In Cold/Cold: In Hot/Cold: Out Cold water supply: Available Drain Hose: Connected .... and as with most condensing dryers, you need to let it run to the end of its cycle - if you take stuff out without running the final 12 minute cooldown period, everything will come out feeling a bit clammy. If those control settings don't help, try a functional faultfinding approach. To dry properly, the machine needs to do four things at once: 1. Tumble the clothes: You can see whether this is happening or not. From your description, it sounds like this is working. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 2. Blow hot air over the clothes: You should be able to hear the fan running, and if you open the door, the air which comes out should be quite warm. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 3. Condense the moisture out of the circulating air: If this isn't happening, the clothes don't get any dryer - they just get increasingly hot. Before making a warranty claim, all you need to do with this problem is ensure that the supplies and settings are such that cold water (and only cold water) is getting to the condenser. 4. Pump out the condensate: If you've just washed successfully, this is probably going to be working fine. If not, then you'll start to see the drum slowly filling with water. If this happens, check the filter (p12 of the manual), then get the warranty claim going. Welcome follow-on questions or news on how you get on posted as a comment to this query. A.
Jun 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
