Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana Side by Side Refrigerator
The water dispenser was not working last week and the next day 1/2 of the freezer was defrosted and the frig didn't seem to be cooling. I cleaned the coils and the fan and unplugged it for a week. I plugged it back in 24 hours ago and it seems to be cooling however, the water is not dispensing again and it's not making ice.
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 29, 2010
My water dispenser quit working on my GE GSH25JFTAW side by side frig (I believe 4 years old). When I defrosted the freezer (because the fan was making a howling noise) and re-assemble it, the water...
Ken
Most likely the water line inside the freezer door is frozen( very common problem.. No long term fix out there other than defrosting the line(you did that when you defrosted the whole fridge) the trick is to run the water a lot the first day or so..sensors and motherboard have nothing to do with that..
Jul 07, 2017 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Amana refrigerator not running but light and water dispenser work
Hi, Remove the front kick plate at the bottom and locate the defrost timer box. You will see a hole and there will be a round switch you can turn. Turn in clock wise and see if the refrigerator starts.
If it starts, the timer needs changed. If it does not starts. locate the cold control (thermostat)
Check continuity on the switch. If it is the on position and the circuit is open, you need to replace it.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
Jun 14, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezing on the refrigerator side even if I lower frig side to 1
you can check to see if the mmotorized damper on the refrigerator is functional by turning it off and checking if the air flow stops and the on and airflow increases. iT MAY BE BINDING UP ON YOU.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Amana Refrigerator leaking in the inside
defrost drain channel is almost certainly blocked in freezer, to rectify turn of overnight leaving doors open, turn on the next day 12 hours later and it should then work ok.
Jun 04, 2007 | Kenmore 44103 Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
105 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
