Question about Samsung LN-S4692D 46 in. LCD HDTV
Samsung TV will not come on, but hear clicking noises until you unplug the tv. Is there a reset button located anywhere on the TV. I have Samsung model# LN46A550P3FXZA
SOURCE: MY SAMSUNG T.V. CLICKS AND WON'T SWITCH ON
I can't take credit for what I am about to suggest. Another user on this site already figured it out. The power board does not have to be replaced. The problem is faulty capacitors on the board. If you are handy, you can replace them in short order. The bad capacitors are the 1000micro-Farad, 10V capacitors. The tops of the capacitor should be flat, but a bad capacitor will have a slightly dome shaped top. It looks swollen at the top, but it's subtle. The user that originally posted the fix reported that some bad capacitors will also have a brown liquid oozing from the top. Anyway, I had the same problem and I replaced two capacitors this weekend for less than $4. It's worth a try if your unit is out of warranty because if you have a repair man come out, you will take a drumming.
Posted on Dec 14, 2009
budmrtn
  • 11361 Answers
SOURCE: Samsung LCD HD TV Model
Th clicking is from the power relay. You will have to open it up, the first place to look will be the power supply module, look to see if it has any bad caps with leaking/bulging tops first, caps can look OK but can be bad due to high ESR.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 18, 2010
walesarumi
  • 6993 Answers
SOURCE: When I turn my 46"
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jan 13, 2011
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
  • 541 Answers
SOURCE: SAMSUMG 46'' LCD TV MODEL LN46A530P1FXZA PROLEM
Check for bad capacitors in the power supply. The capacitors will be bulged on top. Typically there will be 3 or 4 caps with this problem. Thanks for using fixya.
Posted on Jan 23, 2010
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
Hi, I have a Samsung digital photo frame 7" SPF72H. When I attempted to load the driver software from disk a got a warning message stating that this product had not been authenticated by Microsoft and...
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 29, 2008 | Samsung Televison & Video
I hear the fan almost non stop while the tv is on.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
Jul 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
Samsung LCD HD TV Model # LN-S4041D > 4 years old - working fine until today - While watching TV, I heard 2 loud beeps and the TV image was lost - initially frozen pixels and some moments later .......
Jul 17, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Replaced lamp. TV does not respond
Hi, do you hear clicking or like a start up sound? if you do it could be an issue with the ballast,that's the board that powers the lamp.Here's how to replace it: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Does your TV make a "whining, whirling, clicking, or humming noise?" If the TV have the infamous blinking lights problem and you're replaced your lamp without success, it's most likely a problem with your color wheel. The Samsung BP96-00674A color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years. Here's how to replace it:http://guides.fixyourdlp.com/samsung/bp96-01579a.php Also make sure door cover is properly shut and also reset lamp timer by unplugging tv wait 5 min and plug it back again.God bless you!
Sep 30, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
My Samsung TV takes up to 2 hours to come on
Replace any swolen capacitor on the power board.
Sep 01, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Samsung DLP
First try a "hard rest" , unplug tv for 5 minutes then plug it back in when you go to turn it on hold the power button in for a minute or until you hear a beep , if that doesn't work , could several things , let me know if the hard reset works first.
Robby
Apr 17, 2008 | Samsung DLP HL-P5663W 56" TV
Hitachi 61UWX10B 61 in | TV will not turn on after reset | any reset button inside the TV ?
My Hitachi was doing the same thing. The culprit is a bad or intermittent 5V relay on the power supply board.
Jan 30, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Samsung LN-S4692D 46 in. LCD HDTV Logo
265 people viewed this question
Henry  Thomas
Henry Thomas
