Question about Water Heaters
Radiators not heating
Most of the Radiators are not heating. Boiler is working, have hot water ??. The radiator in the attic is the only radiator that is heating. Help !
  • 43,501 Answers
Here is a tip that will help you...
http://www.fixya.com/support/r3705970-heating_circulating_water_pump_problems
heatman101
Posted on Apr 25, 2010
Worcester 350 combi boiler on but water cold and radiators cold. Have put pressure up but made no difference. What's wrong with it?
If the inline pump is not working no hot water will flow into your radiators. The pump pushes the water in the lines to create a water flow. Increasing the pressure will not help in this case. I recommend you put the pressure back down as it usually is preset when the boiler is installed. My pump is about three feet back of the boiler on the intake line. If you don't know what you are doing I recommend getting a repair man as you could create more problems by over heating the boiler its self and blowing the electrical parts up.
Feb 06, 2015 | Water Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Boiler working but radiators cold
Seems that you may have bad circulation pump.
Feb 24, 2013 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
I can only get hot water when i turn the heating on! the boiler is a sime super 90 plus (so it says on the front). i have turned all the radiators in the house off, am i causing damage doing this?
It sounds like you have a bad aquastat, if you have steam heat, and you have closed off the radiators, it will not cause a problem, it will just shut off when you build a couple psi of pressure. I would not recommend the same on a hot water boiler, because it could cause problems if you start making steam. Hope this helps.
Jun 17, 2009 | Water Heaters
Heating pressure gauge goes up
yes tami
there should be a pressure rellief valve fitted.
it also sounds like the heat exchanger is blocked if the hot water is not as good as it used to be and the boiler reaches temperature too quickly then there is scale in the heat exchanger and needs to be cleaned or replaced
Mar 27, 2009 | Water Heaters
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Heating
you need to bleed your radiators - air has built up at top of radiators and water cannot flow- there will be a cover at end of radiator on one end or the other- very carefully turn venting cap until air comes out it will change to water and stop- repeat at all radiators- be sure you are turning right part of vent and be gentle - if it feels like you need Hercules strength -you are turning wrong part.At the end of this go down and verify boiler pressure of 15 psi
Nov 10, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
