Question about Lincoln Conveyor Oven - 1130-080-A
Left burner not up to temp - Lincoln Conveyor Oven - 1130-080-A
  • 106 Answers
1 fit the fingers properly
2 if oven is electic only check all the heating elements if ok
Posted on Jun 14, 2010
Oven won't heat up
When you set the temp, look for an orange glow by the burner. If it isn't there the igniter is bad. It is electric and stays in the flame so it will go bad with time.
Jan 24, 2014 | GE Ovens
Stove wont turn on
Could be a bad burner or a bad mechanism on the temp control. The burner can be removed usually by pulling straight away from the direction it plugs in to. Keep it horizontal while pulling. There will be a little resistance. You can take the burner in to an appliance shop to have it checked. If that isn't the problem, then it's probably the temp control mechanism. If it's really the oven that doesn't work and it is a digital type, try pushing the bake touch pad, then adjust the temperature, then push the bake touch pad
again to engage the oven.
Jun 05, 2012 | Ovens
Tru temp range requires a match to start burner. one of the 4 burners lights the others just click and do not.
There is probably a blockage in the ignition passage or in the burner assembly. Clean everything thoroughly.
Oct 12, 2009 | GE JGRP17 Gas Single Oven
Left front element does not reach temp. I tested continuity and it read 0 !
You must check to see if there is 220 volts at the burner receptacle. If there isn't, replace the switch. You may also find the receptacle contacts worn and not making proper contact with the burner ends.
Sep 01, 2009 | Ovens
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
Too hot
Hi, not sure if you ever received a reply, but there is a setting known as "bypass" on commercial thermostats, if you took the cover off to replace it, you can access this screw, it is part of the body of the thermostat, either to the left or the right of the knob shaft, usually has a "B" stamped, or molded into the body. What this setting does is when the thermostat reaches temperature, it would normally close, shutting off the supply to the burner, thus the temp would begin to fall, by the time it opened back up, the temp would have fallen too much, causing a large temp swing. The bypass setting opens or shuts a passage that "bypasses" the thermostat main valve, keeping just a little burner, making the swing, or fluctuation smaller. So, you probably have a setting too big, causing your bypass flame to be too big, raising, or keeping the temp too high, try turning it in (cw) to lower it slightly, a small turn makes a huge difference, so go easy. Hope that helps, and thank you.
May 08, 2008 | Bakers Pride Y-600 Gas Single Oven
Lincoln Conveyor Oven - 1130-080-A Logo
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Illassist
Level 1 Expert
 Fix Your Board
Fix Your Board
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
