Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
My LG dishwasher (LDF7810WW) makes a whining noise when the motor starts up. It continues on and off when it is running. Is the motor bad?
  • 21 Answers
MINE IS A LG 3850DD3006A AND YES THE GARBAGE DISPOSER GETS STRAWS AND JUNK IN IT. OR THE SCREEN ON THE TOP IS COVERED WITH MACARONI AND CHEESE. OR TWICE IN 4 YEARS THE MOTOR RING SPLIT AND THE MOTOR STARTED TO GRIND THAT RING TILL IT STOPPED ALLTOGETHER.
WHAT A PEACE OF JUNK!!
I ADMIT THE STRAWS ARE THE USERS FALT!
Posted on Nov 25, 2010
FFBD2411NS makes loud whining noise after water is pumped out and continues until pump stops.
Thank you for your inquiry, Robert!
From the information you have provided your Frigidaire dishwasher makes a whining noise after the water has been pumped out. This could be a potential issue with your drain pump or motor. To pinpoint the issue you would need to disassemble your dishwasher and test each component and this would best be done with a certified technician. This will help you avoid personal injury or future problems. Best of luck! -Matt
Jun 13, 2015 | Frigidaire FFBD2411NS
WHY DISHWASHER MAKES A WHINNING NOISE
If the dishwasher is making a loud whining noise, the drain pump or motor bearings are defective, the drain impeller or wash impeller might have worn out. All these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Jul 14, 2014 | LG LDF6810ST Stainless Steel Built-in...
My LG 1415T1 sound horrible when running
Normally when one hears a continuous noise throughout the cycle, it is caused by the pump motor bearing having become wet due to a leaking seal. The roller bearing closest to the seal becomes rusted and then creates this awful noise. The pump impeller is a sealed unit so you will have to replace the pump.
Apr 03, 2014 | LG Dishwashers
LG LDF6810ST whine noise
-After paying an LG serviceman for a home visit, I told to refer to the manual-and there in small print-USE ONLY POWDER CLEANER. Gel and liquids make too much bubbles(thus air) in the hose producing the noise. It will take several washes-but the noise will go away!
Feb 24, 2013 | LG LDF6810ST Stainless Steel Built-in...
As soon as the motor starts up after the dishwasher fills, the motor makes a loud grinding noise that turns into high pitch whining. Water begins leaking from above the pump.
That shows a leaking water seal. Water would run into the motor bearings which then rust and make noise. You probably need the motor / pump kit.
May 20, 2011 | Dishwashers
Whirlpool dishwasher is making a loud whine while running.
Have you found a solution to your whinning? Mine is doing the same thing. Started about two weeks ago.
Mar 21, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Whirlpool Dishwasher Model: GU2500XTPQ3 making loud whining noise
It's most likely coming from the wash motor bearings. Based upon the age of the dishwasher it might be time for a new one. Although it can be fixed by replacing the motor. It's usually easiest to change the entire sump assembly with the motor. You will have a new wash system. Part number W10782773 Dishwasher Pump Motor Part Number 8535150 Sears PartsDirect
Feb 22, 2018 | Dishwashers
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High pitched whining noise from bottom of dishwasher
the arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
Mar 10, 2007 | Baumatic 18 in. BDW45.1 Built-in...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
1,339 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
