Question about HP Compaq Presario SR2150NX PC Desktop
I try to turn on my computer but nothing happens. i looked at it an in the back the green led light is blinking when I have the power cord plugged in so do I have to buy a new power cord?
  • 18 Answers
No. It is likely that your problem is more serious than that. This generally means that an interior component has failed.
If the machine is no longer under warranty, then find a reputable shop to look at your Presario.
Posted on Apr 28, 2010
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
When you press the start button nothing happen not light or start up
First remove the battery and put it back in, you want to make sure it has a good connection.
Next you want to check the power adapter. If it has a built in LED light, it should turn green when plugged into the wall. If it does have a light and the light will not turn on or it blinks, replace the adapter. Next, plug the adapter into the computer, does the LED light change? Example, the LED light was a solid green, when you plug it into the computer it blinks. If the light does something along those lines, then there is a problem with the laptop itself.
If the power adapter does not have an LED light, then you need to use a Multimeter to check if the adapter outputs the right amount of power...which should be around 12 volts.
If the battery and power adapter pass the tests, then you are looking at a hardware issue in the laptop. From your description of the problem, I would guess the motherboard has died or that the charging jack on the motherboard came loose and needs to be replaced or re-soldered.
Two things that would stop the light from coming on, No Power or Motherboard is broken.
May 02, 2010 | Toshiba Satellite M45-S169 Notebook
Computer won't turn on
If the only light you get is a green blinking light in the back of the computer, odds are that your power supply stopped funcitioning properly.
The good news is, it is a relatively easy part to get and install, but you will want to be sure you get one with adequate power for your system.
Additionally, some systems have custom built power supplies, and can be expensive. If you go buy one, be sure to take your old one in for comparison.
Good Luck
tony
May 18, 2009 | Computers & Internet
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Powers on Immediately poers off
This could be a bad memory chip or slot problem. remove the memory and try one chip at a time in each slot. If this doesn't work then the problem will most likely be in the power management system on the motherboard. This will require professional diagnosing in order to track down the exact problem component.
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
HP Compaq Presario SR2150NX PC Desktop Logo
147 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
