Question about Fujitsu Computers & Internet
How to replace the fan in a fujitsu lifebook a3130
  • 159 Answers
SOURCE: I HAVE A PROBLEM W/ MY FUJITSU LIFEBOOK FMV 6866NU
You can download new drivers from here:
http://www.falconfly.de/voodoo2.htm
That's a spectacularly old laptop, fyi. The video card manufacturer went out of business a decade ago.
Posted on Dec 07, 2008
  • 6 Answers
SOURCE: CPU cooling fan failure on Fujitsu Siemens Lifebook 7010D
I have opened dozens of these in the past and i have one in front of me at the moment...the easiest way to do it is. Get a blank white sheet of paper. Close your laptop and turn it face down. Remove all the screws underneath.As you remove the screws put them on the white piece of paper.So if you remove the screw from the top right then put the removed screw on the top right of the blank white page.
When you have all the screw removed the first thing to come off is the section at the on/off button (about 1nch thick covers the six buttons and has the display on it) Open the screen flat and fully extended.Remember at the back you will need to clip off on both side the grey plastic piece.(beside 2 usb connections and network port) when this section comes off you will see 2 screws underneath for the keyboard to come off...I think you will get it from here....
PS: watch out for the wireless button on the front left... this can pop off when putting it all back together....I'd say somewhere like maplin is a good place to look for one of these fans when you have it removed....best of luck
Posted on Mar 31, 2009
romsky79
  • 822 Answers
SOURCE: black screen when turned on
first thing you do is to change the RAM (memory). if still black screen, you have to re-install or format again the laptop.
Posted on Aug 15, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Fujitsu Lifebook laptop will not turn on
It is one of two things and that is hard drive or motherboard. To see which it is, take the hard drive out and start the computer. When it starts, tap the F2 key, if the computer gets into the BIOS and you can make changes, then I would venture to guess the problem lies with your hard drive.
Posted on Oct 02, 2009
parrotheadpc
  • 2600 Answers
SOURCE: How do I replace the fan in my Fujitsu Lifebook
I found this in my archive, it is not the S7020 but it is the S7010. I believe they have the same case design, so this will most likely work for you. It is a aolor picture guide to the disassembly of the laptop.
http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/48-fujitsu-siemens-s7010-disassembly
Posted on Jun 23, 2010
How to remove back panel on Fujitsu LifeBook A3130
Clarification question:
1. Why do you want to remove the back panel?
2. What are you trying to accomplish?
Mar 01, 2013 | Fujitsu LifeBook A3130 Notebook
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
A6020 keyboard replace
Hi and welcome to FixYa!
http://www.laptoppartsexpert.com/i-126239-keyboard.html
http://cgi.ebay.com/Fujitsu-Keyboard-A6020-A3130-CP302772-CP313942-NEW-OEM-/110547912307?pt=PCA_Mice_Trackballs&hash=item19bd2b4673
You have a couple of options here. You can get the one keyboard for 116.00 on the first link, or you can use the second link and get one for 53.00 (new). They currently have 3 left in stock.
You will have to set up an account for eBay if you do not already have one, but this will seriously save you money. The shipping is free.
If this solution helped you, please leave rating!
KittyTech
Nov 15, 2010 | Fujitsu LifeBook A6020/C Notebook
My fujitsu A3130 screen doesnt turn on. the only thing it does is that the 3 lights in the top right corner turn on and off.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 15, 2010 | Fujitsu LifeBook A3130 Notebook
By mistake I changed my BIOS password., but I forgot it. My laptop computer is Fujitsu Lifebook series A3130 Please let me know How I do reset my BIOS security password.
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Aug 19, 2010 | Fujitsu LifeBook A3130 Notebook
Black screen when turned on
Aug 15, 2009 | Fujitsu LifeBook A3130 PC Notebook
Computers & Internet Logo
173 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
