Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell carpet cleaner not sucking up.
Currently own a Bissell Pro Heat carpet cleaner that will not **** up any thing while I clean the carpets, the attachment works but when using it on the floor it will not **** anything up, what can I do to remedy this?
    Scholar:
  • 25 Answers
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Posted on Apr 24, 2010
How do i fix my Bissell pro heat turbo x2 carpet cleaner it wont suck up anything?
Check the vacuum hose and head for link clogs from carpet fibers
Oct 30, 2016 | Bissell Vacuums
How does water heater function on bissell pro heat 1548 carpet cleaner work
It adds heat to the fresh water as it is pumped out on the floor. It will NOT heat cold water enough to clean the carpet. You have to put hot water in the clean water container.
Jul 28, 2016 | Bissell Vacuums
How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell Vacuums
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Brushes not spinning on my Bissell carpet shampooer (pro heat turbo 2X)
Dog hair may cause this, clean this unit, take sissors and cut hair.
Feb 14, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Pro Heat 8910 clogged?
Why the motor sounds muffled I am not sure. When the water is sucked up, it goes directly into the tank. The motor only creates the suction so it can do that. There should be a filter on the rim of the recovery tank lid, is it clean? Other then pulling the top cover off, and then the motor cover so you can inspect the motor, I really don't have a good answer for you. I t may be that that clump of hair when down the chute and into the fan, I have seen that happen with vacuum motors before.
Nov 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
622 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
