Question about Targus Chill Mat PA248U Laptop Cooler
The port inside the fan where one end of the usb cable enters its moving constantly, i need to moved the cable around for the fan to work, i`ve open the fan and tried to tape the port but it doesnt works, what can i do? glue it?
    Scholar:
  • 161 Answers
I assume you are talking about the electrical contacts. The best solution it sounds like is to solder it if you have a soldering iron. I would just buy a new fan if it is a small one.
Posted on Apr 25, 2010
Spy pen not working
If you have a Spy Pen, sometimes it just appears to be either stuck with the light on, or dead and won't turn on. We wrote this report to show you some of the tricks we found to getting your it to work again.
1. Perform A Hard Reset
The majority of the time, just inserting the end of a paper clip in the opening below the status light on the back, and performing a hard reset, will get your Spy Pen working. Just bend a small paper clip end out, and insert straight into the opening. When you meet resistance, push lightly, and you can feel the reset button depressed.
Make sure it goes straight in, and not at an angle, or you could damage some of the components inside. Let go and try to turn it on.
2. Rule Out The USB Cable
If you are using a USB cable to either connect the Spy Pen to your computer, or to the 110V wall charger adapter, one day the cable will fail. If you use the USB cable because you can't connect the pen directly to the computer, try just plugging it directly into the computer.
Don't use a USB hub, as sometimes there is not enough power for the it; just connect it directly to the computers USB port. On some computers, use the USB port on the back, as front USB ports are sometimes weaker.
3. Rule Out The 110V Wall Charger
Just like the USB cable, the 110V wall charger adapter will also fail at some point; so if it does not seem to take a charge, try charging it for 3 hours in the computers USB port. If the status light is on while its charging, its getting electricity to charge the battery.
4. Put The Spy Pen Back In Video Mode
Several Spy Pens have switches to go to photo mode, or voice activation mode. If you move the switch to change modes, and you do not move it back to video mode, the computer will say it is not recognized. Try moving the switch back to the original position.
5. Erase & Reformat The Spy Pen
If the Spy Pen shows up as a removable drive on your PC, just right click on the icon and let go on "Format." Then check the "Quick Format" button, then hit OK. The drive will be erased, and reformatted. This usually takes care of any pens that make it this far.
Feb 13, 2014 | Computers & Internet
Download photos to pc
If you're photos are saved in your phone's internal memory, transfer them first to the memory card.
To move files from the phone to the card, perform the following steps:
1. At the main screen, tap Menu.
2. Tap My Files.
3. Tap Phone at the top of the screen.
4. Tap the desired folder.
5. Tap the desired file.
6. Tap Options.
7. Tap Move to.
8. Tap Memory card.
9. Tap the desired folder.
10. Tap Open.
11. Tap Move to.
Once you have transferred your photos to the card, the next step would be transferring those photos from the card to your computer.
To move files from the card to the computer, perform the following steps:
1. Plug one end of the USB cable into the USB port on the top of your phone.
2. Plug the other end of the USB cable into a USB port on your computer.
3. Click File Transfer on the phone.
4. If required, tap OK on the phone to exit to the main screen.
5. On the computer, in the Removable Disk dialog box, click to select Open folder to view files using Windows Explorer, and click OK.
6. Navigate to the file on your memory card that you wish to copy.
7. Right-click the file and click Copy.
8. Navigate to the desired folder on your computer.
9. Right-click and click Paste.
10. When you are finished transferring files, tap Back on the phone.
11. Tap OK to exit the card reader mode.
12. Disconnect the USB cable from your phone and from your computer.
http://www.cellphones.ca/answers/how-do-i-download-photos-from-my-phone-to-my-pc/
Nov 16, 2012 | Huawei 2x Hb5a2h 1150mah Battery For U7519...
Speedometer is not working on my car
*Check the 2nd end of the cable connected to engine.. move the cable end clockwise and check if the metre is moving. If yes then there is geyor inside the engine area where the 2nd end is connected. you've to replace the geyor.*Check the connection of metre cable with metre... you have to remove metre console.
if its ok then you have to replace the cable.
otherwise you've to repair the metre
Aug 19, 2012 | 1992 Toyota Tercel
Where do you plug it in on the camera
What you are trying to plug,USB cable external microphone?
For USB cable normally the ports are located on the sides of the camera and have the USB symbol on the covering cap.If external microphone or flash check for the top metal shoe
Mar 31, 2011 | Cameras
The usb ports are not woking we had moved into a different home and its not working any more.I have tried the printer on a nother computer in the house and it works.The usb is not working.When I go into...
Your right on the money. What your referring to is damage or dislodged cable. Even quite possible damage due to mishandling or static electricity. Most Best Buys will be able to take a peek inside and tell you.
Jan 12, 2010 | E-Machines eMachines Desktop PC
Power light will not come on.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
If its still under warranty you might consider letting the shop look at it.
If not then open it and check the connections inside after you disconnect it.
Not unknown for them to work loose if the drive moves around a lot.
Sep 04, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
I have a dlink wireless router di 624 air plus xtreme g.
Are you operating the laptop with the wireless on and a cable too? You should probably choose one or the other and not both at the same time.
If you are only operating both computers on a wire then --
Assuming all cables are completely plugged in securely
If the problem is intermittent you may need to use your laptop in a normal fashion -- to see if any movement causes the disconnection. If there is a internottently defective cable when it is in your desktop it may fail less frequently, Meaning, it may work more consistenly because your desktop does not get moved around. (This last instance may avoid detection in this testing process)
Try swapping the laptop's cable with your desktop computer's cable at the computer end and see of the problem moves.
If it does not move you may have a problem with the ethernet port on the laptop -- end of test.
If the problem does not appear -- you may not have an issue or you may have a defective cable probably attached to the desktop now as noted above failing more infrequently so you have not observed it yet.
If it moves you may have either a bad cable or a bad router port -- continue test.
To determine which swap the cable's on the router end this time between the two attached ports (use the same ports with the opposite cable in each).
If the problem moves again it is the router port -- try switching the cable of the non-working machine to a new router port.
If the problem stays put is probably a defective cable. It will probably be easiest to replace the cable.
I hope this helps.
Jan 02, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Cannot use tablet
I had that problem and I found two things that may cause it:
1- Installing the cable at a USB port otherthan the port you used the first time, which would lead to conflict - Try restarting your computer
2- Try removing the driver, restart computer and re-install it again.
regards
Jan 01, 2008 | Genius MousePen 8x6 (MOUSEPEN8X6)
Replacement USB port for my scanner, how can I find the one I need?
If you mean the USB Cable (not USB port as in your question) then you need a standard 'computer to peripheral' cable. It has the regular USB rectangular plug on one end (this part goes into the computer) and an almost-square plug on the other end (this part goes into the scanner.) I say "almost" square because it has two rounded corners to help with orientation.
As additional reference, these types of cables are commonly used to connect USB hubs to computers. For example, the USB hub built into my Dell monitor also uses this standard cable.
One end:
Other end:
Dec 16, 2007 | Epson Perfection 1250 Flatbed Scanner
Computers & Internet Logo
185 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
