Question about Dishwashers
Program runs but it never drains the water at the end can you help please
    President:
  • 949 Answers
The most common cause of this is a restriction in the drain. It can be in the hose where it connects to the dishwasher, but most often it is where the drain hose connects to the kitchen sink. Remove the hose from the sink and make sure the hose and the sink connection are clear.
Posted on Apr 25, 2010
Program ends before full cycle leaving clothes in loads of soapy water, happened twice after once I had pushed end button while red with door lock in red
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the inlet valve water pressure is low then the program might take more time and so result in a error. so check inlet valve flow. Also the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally check the drain pump, if choked the drain cycle will extend and result in error.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Hotpoint First Edition WMA22 Front Load...
Hoover D73 Dishwasher water comes comes and goes, no washing
this is a problem with the timer programme at the end this can be replaced but can be tricky to do your self the water should drain freely out of dishwasher if you feel confident enough taking the back off try finding the drain pipe because uselly these get blocked with either the food off the plates and it can get blocked with limescale if it hasnt been used for a while then the mess has buitl up and set hard if you can get the drain pipe off try running some bleach through it but make sure you clean all the bleach off before putting it back on otherwise everything will smell of bleach this is the only sollution it does sound like the drain p[ipe is blocked the dishwasher will cut off if the water raises in the bottom it does this as a safety feature to stop your kitchen from flooding it is more than likely a blocked pipe so check this properly and the drain in the bottom of the dishwasher as the water shouldnt just sit their it should be draining all the time but i would say clean all pipes properly before you do anything else hope this is some help......................
Nov 02, 2007 | Dishwashers
Sometime the water is not fully out of the clothes at the end of cycle and sonetimes there is a FN code and I push start and it runs the rest of the cycle. Clothes are still wet and fullof water and or FN...
Hi jhoage,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Kenmore HE2 Plus Front Load Washer
My washer does not spin the clothes at the end of the cycle.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
In this case as there is no spinning for drying at the end it is possible that the program cycle is not corrrect and so the voltage at the program ends must be checked before we suspect the controller unit.
Also check the rest of the cycle outputs with a multimeter.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Aug 11, 2011 | Washing Machines
I get an E 13 message. I've detached the drain hose but it was clear. Can't open door or try running any other program. I have a small rug in the washer and I fear it's the cause of the trouble. Please...
To remove the drain pump access cover, insert a pointed object (or tool) into the hole, push in to release the latch and rotate the cover clockwise.
If you have a wet dry shop vac attach it to the end of the drain hose to remove any water.
Then remove the drain pump plug and clear out the area keep the shop vac handy as water will still come out of the plug.
Once this is clear you machine will start.
There is also a white plastic zip tie like cord you can pull in order to open the door
Jan 09, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My Miele G646sc dishwasher is not heating the water and therefore there is deposit of water at the end of the cycle. Please help.
Both the issues seems to be apart. The loss of heating is due to failure of the heating coil, failure of the heating coil control relay , failure of the program controller unit.
All of this must be checked with a multimeter only if you are able to remove and check the control panel of the washer.
Secondly the drain pump/valve can be clogged and is not fully exiting the water after the program comes to an end as the time given to pump out is not sufficient due to low flow - clogging with dirt.
Remove the drain hose/ drain pump and clean the filters , reset the valve/pump to test.
Jan 06, 2011 | Dishwashers
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
Water runs continuously tub never fills My Fisher & Paykel top loader keeps filling and draining at the same time. It never gets full of water. The hose is way higher than the machine, but still drains...
where is water draining into? have u got grey water hose attached to it?make sure u can see end of drain hose, put into bucket at lid level, if it still drains as it fills u have a faulty control module.please reply for more help
Apr 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Dishwashers Logo
Top Dishwashers Experts
