Question about RTO PasLode 900420 Impulse Framing Nailer
Impulse gun wont fire and fan doesnt run
Green light on handle flashes I have a full clip of nails in it , fully charged battery, but the fan wont run and my paslode impulse framing nailer wont shoot
  • 2,176 Answers
Could be a bent probe not allowing full travel of the safety , fan motor, loose wire, or circuit assembly. If you are handy with tools, remove the battery and fuel cell. remove the 4 screws holding the cover on top of the cylinder assembly and down where the saety is remove the 2 screws there also. gently pull the cylinder off the tool. when you have apart check toe condition of the Oring on the top plate where the fan motor is. Now reinsert the battery and you will see a rocker switch towards the top, depress it and the fan motor should come on. if not try and depress the trigger switch and again the fan motor should come on. If neither start looking for loose or broken wires, if you find none then I would guess the terminal board would be bad. you can also remove the handle halves and look for a loose connection at the board itself, they sometimes wiggled loose where it plugs in. Good luck and let me know.
Posted on Apr 25, 2010
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
Why doesnt my nail gun, straight nail finisher wont fire?
I need to have a little more information.
Is the green light flashing on the handle?
Does the fan run when you depress the nose?
The most common problem we see with these is bad / expired fuel - be sure to check the date stamped on the bottom of the fuel cell.
One other basic thing to check:
Bent lower probe - these are very prone to bending & that will prevent it from traveling fully and making the head switch inside.
If you still have problems please post more information about what the tool does / doesn't do and I'll talk you through troubleshooting.
Aug 04, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have a new im65a pasloade nail gun that has only fired a couple of hundred nails and after standing for about 16 months the gun does not seem to be firing the fan comes on the green light flash the
your gas has expired , look at bottom of canister check the date. buy new gas also make sure cap on gas canister is down all the way till it snapps new gas doesnt come with cap down all the way
Apr 24, 2012 | Senco Air Tools & Compressors
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
Jun 23, 2011 | Air Tools & Compressors
Gun will not fire, battery is charged & good ??? model #IM25011 part # 900400 Bob
problem solved - battery charger indicated that battery was charged with green light on, took battery ouit & placed it back in charger & red light came on after doing this three times the battery was fully charged and the gun worked fine.
thanksBob
Jan 29, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 1st fix gun .battery fully charged and placed into gun.the light flashes green and the gun will fire once after which the light flashes red and the gun will not fire.any ideas.i have tryed other...
I would look at the fuel cell on the bottom is a expiration date and they will not fire older fuel. Also do you remove the battery and it does the same thing? When you depress the safety on the work can you hear the fan motor? You say the tool is clean does it have enough lube to move all items freely. Just a couple thoughts, Also look at the spark plug wire for being broke or coming out of the spark unit. Let me know and we will go into this deeper.
Jun 30, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Sep 28, 2008 | Hitachi NR90GR Cordless Round Head Gas...
RTO PasLode 900420 Impulse Framing Nailer  Logo
555 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
