Question about Frigidaire Washing Machines
Replace the drain hose on my frigidaire fwx233res4
How do i replace the drain hose on my frigidair FWX233RES4? can't figure out how to get to it.
  • 8,197 Answers
Between the top and front panel on the left and right sides are little clips. Insert a screw driver and pop the top up. Next, remove the two screws at the bottom of the front panel and then push down on the front panel to remove it. Your hose will be in view.
Posted on Apr 24, 2010
Replace drain hose
Thank you for your inquiry, friend!
From my understanding you need to replace the air breaker and drain hose within your Frigidaire dishwasher. Some of these intricate part replacements do require precision and patience. I would recommend seeking a professional technician for assistance because one must be very careful as there certain replacement parts could result in potential harm. Best regards. -Matt
Oct 15, 2014 | Frigidaire FPHD2491K Builtin Dishwasher
How to clean drain hose to frigidaire affinity front loader
One of the best ways to clean the drain hoze of a washing machine is to spool up the hose and place it into a bucket with at least 2 cups of vinegar (white or cider) and enough water to cover the disconnecfed hose. Soak overnight and rinse well before reinstalling.
Jul 18, 2014 | Frigidaire Affinity ATF7000E Front Load...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 21, 2011 | Frigidaire Washing Machines
Frigidaire front load washer GLTF2940FS barely drains at all. Hose is clear of debris and properly positioned in house drain (6 to 8 inches). Is there a drain pump filter that is accessible from the back?...
Yes, there is a filter on your machine. If you look in from the back, on the bottom of the tub is a hose coming off. Remove the hose from the tub section and inside of it you will find the filter.
Have a great New Year!
Jan 03, 2011 | Frigidaire GLTF2940F Front Load Washer
Slow letting out of water
Hi, Remove the two screws at the bottom of the front panle. Then insert a flat blade screw driver into the gap between the top and the front panel. There are spring clips on each end. The front panel should then drop down and release.You will be able to see all the hoses.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Washing Machines
Frigidaire FWX233RES4 washing machine won't work
Sounds like there's something such as a small sock that has gotten sucked into the pump. This will keep the pump from spinning, cause extra noise, and the belts may appear fine but it may be stretched... if you're willing to deal with a little disassembly, unhooking hoses, spilling some water, you can probably handle this.... Good luck and let me know if you need any more assistance..
K
May 10, 2009 | Washing Machines
the humming noise is problably the drain pump, which problably has something (sock or such) blocking it, by removingthe fornt panel youlll be able to acess t hdrain pump assy, to check for a blocklage,,( UNPLUG UNIT LIVE WIRES!!!)
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fridgedaire FWX233RES4 top loading washer won't drain or spin.
check the lid switch. it is the one closing when ever you close the lid of the unit.
once the lid is close, the contact should be closed, if the lid is open, the contact is open also.
tnx 4 using fixya,
drcool
Sep 15, 2008 | Washing Machines
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
