Question about Canon PowerShot A75 Digital Camera
Camera does not display the pictures
My camera does display the pictures from my memory card but it won't take new pictures. When I take a picture you can not see anything on the display and it doesn't take the picture. It makes a funny shutter sound when I click the button but doesn't actually take the picture.
  • Canon Master
  • 4,738 Answers
Have you checked to see if there are picture files when you click the shutter. If so, do the resulting picture files show black images? If so, this would be a defective CCD imager. Canon would also fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 23, 2008
SOURCE:
My camera won't display pictures back that I've taken. Is there a way to recover photos from memory vard?
I'd recommend that you use asoftech photo recovery which helped me before, this picture recovery program is very good for recovering photos from memory card
http://www.asoftech.com/apr/
Sep 14, 2011 | Kodak EasyShare C330 Digital Camera
I have had my camera for 3 years but never had bought a memory card for it. I recently purchased one from Walmart. When i put the memory card in the digital display almost gets stuck and won't open so...
The camera takes SD cards up to 2GB (not SDHC cards). If you've been taking pictures using the camera's internal memory, you must first get rid of those pics. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert your new card and go through the "format" routine again to prepare the new card.
Sep 02, 2011 | Konaki DV7-Z Digital Camera
Can I download pictures from internal memory directly to my computer for a NIkon coolpix S570 camera? The memory card I was using went bad and the camera displays "This card cannot be used"
You can connect the camera to the computer with the USB port. If there's no memory card in the camera, the computer should see the pictures in the internal memory.
Alternatively, you can get a new memory card (you're going to need one, right?) and copy the pictures from the internal memory to the card, then put the card into a card reader and transfer the pictures taht way.
Aug 15, 2011 | Nikon COOLPIX S570 Digital Camera
I have a Canon Powershot camera. While I was on holildays I ran out of room on my memory card so started deleting some older photos. After deleting half a dozen or so, the picture on the display showed a...
Two things to try: 1. Go into the camera menu and find "reset" to get the camera back to factory default settings. 2. With the new card installed, go into the menu and find "format"...follow the on-screen instructions. If the new card now works, you will probably need to do the same with the old card but download the pictures first using a card reader if necessary because formatting will completely erase it.
Oct 28, 2010 | Canon PowerShot SD600 Digital Camera
I want to download my photo's from camera to hp laptop
After you take pictures with your digital camera, you'll want to copy the pictures from your camera to your computer so you can print them, share them with others, and back them up for safe keeping. Once your pictures are on your computer, you can erase them from your camera, freeing up memory so you can take more pictures. You can also view your pictures on a larger screen and decide which ones are worth keeping. Some digital cameras come with software that helps you copy pictures from your camera to your computer. You can use this software, but you don't have to. Windows XP can copy pictures to your computer without requiring additional software. Here's how to copy your pictures using Windows XP: 1. First connect your digital camera to your computer. You can do this in two different ways: ?Use a USB cable. Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer. ?Use a memory card and memory card reader. A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk. Tip: It's usually faster to use a memory card reader to copy your pictures than to connect your camera to your computer with a cable. 2. Once you've connected your camera to your computer or inserted your memory card into your memory card reader, Windows XP will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK. If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK. 3. When the Scanner and Camera Wizard appears, click Next. 4. All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next. 5. On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures. Tip: Create a new folder for each group of pictures you download. 6. If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card. 7. On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next. 8. On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera. Your photos are now stored on your computer, ready for whatever you want to do with them, and your camera is ready to take more pictures. As with any important files, it's a good idea to make backup copies of your photos, in case anything happens to your computer
Apr 08, 2010 | HP Photosmart M547 Digital Camera
Internal Memory full; No memory card in; Will not take pictures;
You need to get a memory card and promise to never use the internal memory again....it only causes problems as you have found out. When you get the new card follow this procedure: 1. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to format the internal memory. 2. Insert the new card and do the format thing again to prepare the new card. Happy photography!
Mar 14, 2010 | Kodak EASYSHARE Z1285 Digital Camera
When transfering pictures from camera to PC EasyShare will not transfer some pictures. "picture already exists" in My Collection. These are all new pictures taken with blank memory card. This occurs even...
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
Dec 26, 2009 | Kodak EASYSHARE M1063 Digital Camera
No memory space in internal memory-no more pictures can be taken!
there may be two problems. 1. Format your card before using it. 2. Switch your storage device to memory card and it will work. Hope it works..:))
Mar 10, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
A "format error" display on screen
when i want to take a picture with my memory card in it, it says format error, and when i take my memory card out it seems to take a picture. what can i do to keep the memory card in and take a picture
Feb 07, 2009 | Vivitar ViviCam 5150s Digital Camera
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Canon PowerShot A75 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
