Question about Hitachi 43UWX10B 43" Rear Projection Television
Convergence problem I have replaced ic with new updates and 2 new resistor had the board solder at electronic shop. reinstalled need help manually adjusting convergence
  • 53 Answers
Well you need to get into your tv's service menu and service convergence mode. It's different for every tv. It means entering a code on the remote that opens up a secret menu for changing tv settings. Go to servicemanual.net and buy the service manual for your set, you'll be glad you did.
Posted on Mar 25, 2008
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I need help my phillips model 46pp930217f hdtv . i can't get the colors to aline what part do i need to replace help plz and i need the modle number to plz my email is russianmexican@live.ca
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B are mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board is dead,the tv convergence board,must be requiring to replaced 2 STK convergence ICS and some or all of it resistors too.U have all the tools and can do ICS soldering and electronic componnents soldering.Tries websites like Tvrepairworld.com,Tvreparkits.com to buy a Convergence kit to do the repair ur self.Or the shop,will cost u like $300-350 for parts and labors.
Dec 15, 2010 | Philips 51PW9303 51" Rear Projection...
My tv has lots of red and green. Faces are shadowed by a red outline. It occurs on all channels and dvd.
If problem does not fix by flash focus/ convergence adjustment in Menu then replace convergence output ICs on D board of tv that sounds defective and causing problem.
Comvergence output ICs replacement requires soldering work with proper tools and electronics knowledge/ experience, call local tech if you have no experience.
Jul 16, 2010 | Sony KP-51WS510 51" Rear Projection...
JVC AV-48WP30 , how to change convergence
First of all tools,requirement to do the work on the Convergence board to do changes the 2 STK convergence ICS and some or all it resistors.U have a soldering iron,desoldering pump or soldering wicks and solders?Don't?must buy to do desoldering and soldering?Tries Amazon.com to buy solders.Tries wesites like Tvrepairworld.com to buy the convergence kit to replaced ur self,and buy the soldering iron here it have the desoldering pump attach to the sodering iron it self.For video tutoring how to take out convergence board out of the tv and replacing the 2 STK covergence ICS and some or all it resistors.Might included in the buying of the convergence kit,not,Try You Tube type in convergence problems,will have video some body doing it.
Jun 07, 2010 | JVC AV-48WP30 48" Rear Projection...
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
JVC AV56wp74 convergence. Resistor before ICs?
It's recommended to replace all the defective parts first because if you only replace the defective resistor, it might burnt again if the convergence IC is shorted internally. I would also suggest to measure the other low value resistors with multimeter.
Oct 30, 2009 | JVC AV-56WP74 56" Rear Projection...
We have a problem with the ghosts. double people and colors are all over the place. went to convergence and tried to enter to go to auto or even manual but only got lines of different colors can we fix...
Need a repairman - unless you've done soldering and electronic component replacement b4.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | JVC AV-65WP74 Rear Projection Television
Picture bends in different colors
your Convergence IC chips and resistors arre failing you need to replace them
below is a general disscussion post for a Philips TV which will help you to understand your situation and what you might need usally you will need (2) IC convergence Chips and usally (12) Resisitors what have to be soldered onthe the board after you remove the old ones. this fix usally cost you to do it yourself $30, to have a repair man do it cost around $300-450 a new board if avalible usally costs $250-300
Sorry, for the bad new I hope you have a friend that knows how to work on circuit boards...
good luck,
below is a general post about a philips TV Convergence problem you can read about keep inmind your CHIP and RESISTORS will proball be different type....
you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Nov 20, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Have a philips magnavox 8p6044 c102
Hmmm... I dont know where to find those CTR Circuit boards I'll post my general post for you about what I know it has links to the manual and some other sites it may help.
how bad is it burned, did some chips go or just the copper circuit board tracers. you can use circuit board wire and solder it from point to point,
I had somewhat of the same problem with my IC board, I had a bad portion of the board where I had to build a new copper routing with circuit wire, the copper burned off when the resistor failed, you may need to do a little Frankenstein work on your board as a last resort... remember use a low 15 watt soldering pencil, use leaded solder, and USE flux!
however with all my work, I got it running but the IC board is still not running perfect. if you decide you cant fix the TV I would love to buy your IC convergence board from you.
GOOD LUCK! hope I helped...
GENERAL POST WITH LINKS BELOW.....
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
What you need:
(2) STK392-120 OR STK392-150 IC chips
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
BLUE HAZE AROUND ALL WORDS
Hello JPKLASSI,
Check your convergence first, use the AUTO adjust feature first then see if this clears up the problem. If the Auto adjust does not work then the following may be in order:
Only do this if you have a background in electronics, if you do not get a qualified TV technician to work on this set.
If you choose to do this yourself, here are the basic instructions:
1. Unplug the TV set
2. Take the rear bottom panel off
3. look for a large heat sink with two large black ICs (STK392-110) (6 sided components but rectangular in shape) on it, and remove the board the ICs are on from the TV set.
4. Unsolder the components using a soldering iron and a suction solder remover.
5. disconnect the components (ICs) from the heat sink
6. Unsolder all of the bias resistors and replace them with the proper values (usually 220, 150, 3.3, 2.2, and 3.9 ohms)
7. install the new ICs (STK392-110)
8. solder all connections IC and bias resistors
9. Inspect for shorts
10. reinstall circuit board
11. Plug the TV set in and turn it on.
I hope this helps
Thank you,
Shuttle83
Oct 03, 2008 | Televison & Video
Hitachi 43UWX10B 43" Rear Projection Television Logo
97 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
