Question about Panasonic Lumix DMC-FZ20 Digital Camera
No power the camera stopped operating, and when freshly charged battery was installed it still had did not turn on. When putting the battery in, noticed that the battery & charger have 4 contact slots/posts - but the camera has only 3 contact posts. Is that normal, or could 1 of them broken off? If normal, what else could be the problem? Absolutely love the camera & want to have it fixed. Please help. Phil
  • propen05 Dec 05, 2010
    Did you get the camera repaired - If so what was the price ? This exact thing just happened to me as well ! - Even bought a new battery first as I thought it had gone flat with no charge. new battery - no change. Cheers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 59 Answers
They only have three connectors in the camera, unfortunately, you may be looking at a repair bill or replacement, as the minimum cost to repair may be more than replacement cost. i have an FZ 15 and love it, but the newer ones do much better especially in darker settings, I also have an FZ 18, seems cheaper, but good photos, the FZ 28 I think is the current one, but a step up would be better if your wallet allows, you are used to a heck of a good camera and the replacement needs to be a good one!
Posted on Apr 25, 2010
Camera does not recognize batteries.
Your batteries are worn out and need replacing for new fresh ones. They are charging, but not holding the charge. If they are new, they are fakes or worn out.
You can buy batteries which have a higher capacity, more MaH (milli-amp hour) than your current ones.
Having a quick Google, it is a known problem.
try this ... i had the same problem with the same camera and this fixed it.
remove the battery, and remove the memory card ... then re-install the battery & turn on the camera.
this process seems to reset the camera, if the battery ran too low.
now you can re-install the memory card & battery and resume normal operation.
be sure to check for the small flashing green light on the back of the camera (next to the "flash" indicator symbol). it should be blinking when the camera is charging.
i hope this helps you.
nikon coolpix battery exhausted message Google Search
Feb 10, 2018 | Nikon Coolpix 4600 Digital Camera
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Hello
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 02, 2010 | Kodak EASYSHARE M1063 Digital Camera
Hello. My v1233 powers on, I am prompted to put
4. Please test with the a different battery
  1. Please take the battery out of the camera.
Steps for uploading new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://wwwuk.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11647/11660&product=EKN033563
If successful please give me the feedback as a rating or recommendation. Thank You
Dec 08, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
I put in a freshly charged battery and go shoot a youth football game. After a series of shots, my battery is "dead". I turn the camera off and then back on and can get a few more shots before it goes dead...
How about cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol? It also wouldn't hurt to visit the support section of the Nikon website to see if they've posted any firmware updates.
Oct 09, 2009 | Nikon D300 Body Only Digital Camera
Nikon SB-800 Defect
Have you tried other batteries?
If one cell has died, there will be enough power to power up the flash, but not enough to charge it reasonably fast. It may also stop the other cells charging up properly if they are charged together. I've had this problem with poor quality rechargeables before. I think flashguns put pretty heavy demands on batteries.
Oct 23, 2007 | Nikon Speedlight SB-800 TTL Flash
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
120 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
