My phillips 170s monitor comes on for 2 seconds then goes blank screen. when i turn it off/on it does the same but doesnt go into standby mode. please give me some assistance. thank you.
  • mark_picton Apr 15, 2009
    Mine's the same too, it won't last 2 seconds though and there's a really faint image of the desktop trying to get through, if i turn it off-on again the same happens
  • 23 Answers
Just open it up and check your capacitors. I just fixed two doing this.
Posted on Apr 27, 2009
SOURCE:
My monitor won't come out of sleep mode
Try unplugging the power cord from the monitor for 10 seconds and plugging it back in.
Jan 31, 2018 | Westinghouse Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
My phillips brilliance 170s monitors colour is sparking...after 1 or 2 second...and the screen is discoloured now...what can i do with it?
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Mar 31, 2012 | Philips Computers & Internet
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
When turn on, get a picture for a fraction of a second then blank
you need your power supply repaired. you have bad capacitors.
Jan 01, 2010 | Samsung 225BW Monitor
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
[email protected].
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
My monitor is upside down
my phillips monitor 170s has the brightness screen and the OSD controls locked/unlock how do I fix this
Jun 03, 2008 | Philips 170S4FG 17" LCD Monitor
Open Questions:
Computers & Internet Logo
330 people viewed this question
Ekse
Alun Cox
