Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Sensitive Temp adjustment through shower.
Turn water on through tub spout and temp is easy to adjust. Flip to shower and water gets hot and is very sensitive to adjust. You have to turn way over to cold, then very gently turn back to hot to get warm water. I have this problem in two bathrooms. I replaced the inner valve and did not help. Both are Moen Chateau single handle....older.
  • 20 Answers
Pull the trim off of the valve and you will see a 1 inch diameter flat screw, unscrew that and clean it out and try it again. If rinsing it doesn't work you may need to replace it. It is called a balancing caulk.
Posted on May 02, 2010
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
We have two new faucets in tub, They are both 144910 the question is how do we turn the force of the water down? The plumber that installed them could'nt help. Please advice what to do. I turned the hot...
if the water pressure is high all thru the house then turn down the valve on water main or or if well adjust cut in -cut out or valve down a bit if just high at tubs can adjust valves on water line can install a water saver behind shower head or if u have access to the valve body in wall there are adjustments on both sides where the water lines come into -----if this is about temp in ur paperwork advises how to adjust the anti-scold --remove handle and trim will see a blue and red plastic clip on valve stem adjust till temp is comfortable
Aug 22, 2010 | Delta Faucet Home
How do you adjust temp. water luke warm? This is a single handle. Hot water set at 145.
These type faucets have anti scald dial setting that if you remove the handle you can gain access to it.
Just remove handle and mark or remember where it is and pull it out and reinsert it about 1/4 turn counter clockwise.
It has got marks on it and looks like a little gear.
May 19, 2010 | Danze & Single Handle Tub And Shower...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
When I push the faucet to off I get med fast
push down the tub-spout lift rod and it will empty the remaining water that is between the shower valve and the tub spout
Mar 10, 2010 | Moen Posi-Temp Single HandleTub And Shower...
My shower has been leaking for months. someone
turn the water off to the shower,sometimes you must shut down the whole house at the main ,near the water meter,then take the handle off slide the clip in front up and out then pull posi-temp straight out.replace posi-temp in reverse order.be mindful of the H/C indicator on posi-temp this will ensure you have hot and cold on right sides,if reversed just flip posi-temp.
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
546 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
