Question about GE GTS22KBP Top Freezer Refrigerator
Door is shutting but not hitting the light switch to turn off light inside fridge. how do i adjust the door up.
    Sergeant:
  • 239 Answers
Pull bottom hinge, go to ace get nylon bushing to fit over it
Posted on Apr 25, 2010
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
Light stays on -Refrigerator side
if you can find the light switch depress it and see if the light shuts off if it does then the door is probably not hitting the switch enough to shut the light off. Adjusting the door should fix this.
Jul 23, 2014 | Kenmore Refrigerators
Lights wont turn off on fridge
You have a short to ground somewhere.
Nov 24, 2012 | Kenmore Refrigerators
Mitsubishi fridge freezer
Ice hitting the fan inside? Check the fan by pushing the switch behind the door that turns the light off and starts the fan. Defrost it properly.
May 04, 2012 | Refrigerators
Side by Side refrigerator will not dispense water or ice unless you push the door to the freezer in very tight. Does the door need adjusting?
I would certainly say it does sound like a door adjustment issue. Get a volunteer to help you in this simple test..
Open the freezer door, locate and press in the light switch. Have your helper press the dispenser button and see if it works.
You will most likely find that the door is not hitting the light witch enough to allow the dispenser to work.
The important thing to check is that the freezer light is shutting off when the door is closed! This could create major issues having the light acting as a heater in the freezer.
If you find the door sitting low, check the spacers at the bottom of the door to be sure they are in tact and the alignment of the door in relation to the fridge door.
The top hinge is usually adjustable left to right to even up the spacing, but if your spacers are worn at the bottom you will need to get some new ones.
Good luck!!
Jun 14, 2010 | Refrigerators
Refrigerator inside light will not go out when door closes
This can be due to one of two things, either the door is not hitting the light switch when it closes or the light switch is bad.
Locate the switch, it is usually on the top of the cabinet inside the refrigerator, push the switch, if the light does not go out then the switch is bad, if the light goes out the door needs adjusted so it will hit the switch when it closes. Typically this can be done by loosening the hinges and holding the door in place while someone tightens the hinges back up.
May 08, 2010 | Kenmore Freezers
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
The inside light doesn't shut off
Open one door at a time and press the door button-switch (in the door-frame, hinge side usually) to see if that switch will shut off the light. If you find one that does, either extend the button length slightly with hot glue or epoxy, or replace the switch. Make sure the light has not been turned on at the light or that the switch is bad.
Nov 15, 2009 | 2004 Ford Crown Victoria
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Fridge bulb burns out in fridge side
check to see if the light is turning off when you close the refrig door. its possible the door is out of adjustment and is not hitting the light switch properly when the door closes
Dec 12, 2007 | Kenmore 53642 / 53644 Side by Side...
GE GTS22KBP Top Freezer Refrigerator Logo
50 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
