Question about Marvin Dryers
I am searching for a Marvin box fan, Whirlcool, and the Marvin 1210 floor box fan. Can you please help?
  • 8,197 Answers
You can get the fans on the links below. Just to let you know the 1210 is no longer available.
http://www.fingerhut.com/ProductGroup.aspx?offergroupxid=48501&categoryxid=380
Here is the 1210
http://www.shopping.com/xPO-Marvin-12-Inches-Studio
Posted on Apr 24, 2010
Marvin Model 1220. I have several of these fans and each one has issues with fan blades either not turning or slowing down and eventually stopping. I took one of the fans apart and found that the bearings...
I own a Marvin model 1220 box fan since 10 years ago. The stand broke on the hooks part. I need the buy the same, please help me on this. It is out of stock in the Internet. This fan is fantastic, but need to keep it clean so the blades don't slow down do to dust
Aug 12, 2011 | Marvin 1210 Floor / Box Fan
Broken grill Panels
Pls try here and look for an authorized parts distributor near you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lakewood 200I Floor / Box Fan
I have a Marvin 1210 window fan with a rotating front grill. The grill has come unscrewed from the fan motor shaft and I can not see how to take the front nose cone apart to get to the screw so I can...
mcdevito75 here, hello ken, I did a fast search and I think www. shop.com can help you out with Marvin air fans, I didn"t find anything on Marvin Air Fans itself. Now about the nose cone covering the nut holding the blade to the fan shaft, most of these nose covers are press fit, see if you can gently pry that nose cover off with a small screwdriver.
Jul 23, 2010 | Marvin 1210 Floor / Box Fan
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
Heater fan noise
trw www.sears.com the parts dept...have make and model ready!
Dec 10, 2008 | Marvin 2060 Compact Heater
Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
Jul 03, 2008 | Marvin 1210 Floor / Box Fan
Fan blades
their is problem in push! change your fan push! then the wings are rotate
Jun 29, 2008 | Marvin 1210 Floor / Box Fan
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
Wires for fan speed came undone.
Try here or buy a new fan..©1999 Electric Trading Co. All rights reserved PO Box 692, New York, NY 10013 | Tel: (212) 226-0575 | Fax: (212) 941-1796 | sales@blowerwheel.com Serving the industry since 1903
Aug 02, 2006 | WeatherWorks DB888 Floor / Box Fan
Dryers Logo
365 people viewed this question
Top Marvin Dryers Experts
Are you a Marvin Dryer Expert? Answer questions, earn points and help others
