Question about Acer AL2017 20" LCD Monitor
My monitor was working fine but now it won't turn on. Nothing was happening when it suddenly went off.The light is also not on and I have tried a few different power cables and plugs. It is an acer monitor model number AL2017. What can I try?
  • 11,361 Answers
Nost failures are due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 25, 2010
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
So. My Samsung 906bw monitor was working about a month ago fine. Then all of a sudden, the monitor refuses to turn on. The power light turns on and off and continues to do that but nothing happens....
I opened up 2 of my 906bw and found 3 caps in the power board bulging. They are C316, C112 and C113 they are all 25v 820uF
I'm going to replace and see what happens. Maybe try a higher V see if it helps longevity.
Jan 03, 2011 | Samsung 906BW LCD Monitor
I have a dell monitor (2002) and all of a sudden when I try to turn the computer on I get blinking yellow light and (took to Best Buy and computer is fine) when I hit the buttons on monitor I get (power...
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
Jun 15, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
LG W22h2TQ monitor just turned black
easy way to find out go to bestbuy and purchase a video card and install it if everything works out its the video card if not then its the monitor that went bad if its still under warranty send it back and get a replacement,
Dec 15, 2008 | LG W2252TQ Monitor
1995 Bonneville
the problem is probably one of the battery cables. check for looseness and corrosion. especially at the positive battery connection where the two cables are stacked.
Nov 11, 2008 | 1995 Pontiac Bonneville
Acer AL2017 20" LCD Monitor Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
