Question about Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by
Plastic piece at top of tank spraying water after flushing all out of tank and everywhere! How do I repair or what can I do??
  • Anonymous Mar 18, 2014
    White plastic think at top of tank
  • 23 Answers
Look at the bottom of the system there will be a small plastic U-bend about 1.5 inch long by about 1/2 inch widethat has dropped off silply insert it into the top of the system where the water is coming out of and push firmly.
Posted on Apr 25, 2010
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
Feb 16, 2013 | Kohler Toilet - One Piece with Ingenium...
Water sprays out of the top of the tank when flushed. it then streams down the side of the tank.
If you take off the top lid of the tank you will probably see a little small hose that is unattached. If you flush, water will shoot out of that little hose. The hose should be sticking down into the tube (cylinder) that stands up in the tank and shooting the water down the cylinder. It should be attached to the top of the cylinder by a small clip.
Mar 29, 2011 | Toto Home
Toilet was working perfect this morning until I flushed it and then the water would not stop. I turned the water off completely
The Shut-off mechanism inside the toilet tank is staying open. Turn the water back on, Remove the tank lid and flush to see exactly what is going on. You should notice that the rubber piece of the mechanism does not go back down to cover the flush hole. That should be your problem. Spray some lubricant (WD-40) on the moving hinge at the top of it or replace the entire assembly.
Jan 14, 2011 | Sloan M-101526-F42 Flushmate?® Complete...
The top tank of my toliet wont stop filling. water is coming out of the flush lever??? I had to turn the water off to it
Your Fill Valve needs to be replaced. The life of the Fill Valve can be shortened by the hardness of water or by using tabs to keep the bowl clean. If it is a one piece toilet, use the Korky adjustable Fill Valve. If it's a two piece, use the Fluidmaster 400A. If you attempt this make sure you turn off the water supply valve and flush all the water out of the tank. When you go to tighten the plastic screw, be very gentle and don't overtighten because the tank WILL crack otherwise. Hope this helps!
Nov 26, 2010 | Home
Water leaking on floor...when flush..no urine water
Before you flush the toilet, take the top cover off the tank.
Then flush.. Sometimes water sprays from the float valve,
sprays up against the underside of the cover, then runs down
the back of the toilet.
All my best to you.
LeRoy
Nov 01, 2010 | Toto - Toilet - One-piece - Ultramax -...
When flushed, not enough water coming from bowl rim holes to wash waste off sides of bowl. Have checked holes around top rim, none are plugged. This has been a problem since purchased one year ago.
Its simple. Check to see if you installed toliet right by removing top of tank and holding handle all the way down. Did it flush from all rim holes? If not, then u will need to get a garden hose with a sprayer to increase pressure and shot high volocity water at rim holes to unblock it. Remember the very front on newer blows do not have holes its a pee shield. Also try doing these other things adjust screw inside tank to make sure the bowl has enough water in it to do a good job. Check the rubber tube going into the hollow pipe and make sure it is going fully inside the plastic pipe that is sticking out of the top of the water in the tank. Also you need to have enough water in tank to allow it to flush good. To increase tank water levels then just unscrew the big plastic ball (or just bend wire to allow more water or bend to allow less water) at top of water in tank. Also increase (max) water pressure at wall to allow it to work at its best. If you have hard water it can cause problems but you say it happened even new, so, you do not have to go in that direction.
Oct 06, 2010 | Kohler K-3497 Cimarron Comfort Height...
Water spits out of toilet bowl when toilet is flushed
If your referring to the tank, take the lid off and make sure the small tube is connected from the filler valve to the top of the overflow tube. If that's connected properly, flush the toilet with the tank top off and locate the source of the spray. A small crack in the fill valve can cause a significant spray.
Jul 09, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Hot water tap - no pressure and splutters
Do you have your own hot water tank? or is there one serving many units? There is a 'dip tube' in hot water tanks, if it gets old it sometimes deteriorates and small parts of plastic get loose and will float around in the tank, if a piece finds it way up to the outlet then that might explain why you are getting the low water pressure. one wat to check is to twist off the aerotor on the end of your faucet, if there are any small pieces of white plastic then you will have to replace the dip tube and maybe even flush out the tank. it is also possible that a piece of plastic has traveled up the water line and it stuck in the faucet cartridge.
Feb 11, 2009 | Stone Plumbing
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Dec 26, 2008 | Kohler K-3360-G Revival One-Piece Toilet...
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
169 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
