Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Nothing on the top shelf is getting wet - Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
    President:
  • 949 Answers
It sounds like you are not getting the full pump pressure you need. I put together a cleaning guide, let me know if you try it and it works or not.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on Apr 25, 2010
Where do I locate the evaporator on my fridge
Hi, what kind of refrigerator is it? The evaporator is generally on the back wall of the freezer, it usually has cover over it with some vent holes.
Dec 04, 2014 | Refrigerators
How do you clean a lens in a 5 cd changer panasonic sa-ak27
You should take it out, wet some cotton sticks with WD40 and some ethanol and then clean it with it, the stick must be just slightly wet
Jan 22, 2013 | Panasonic SC-AK27 Shelf System
I have an Amana tr21v2l. The top of the refrig. is always wet and drips onto the food on the first shelf. Everything else works fine. Any suggestions?
sounds like its not giving a complete defrost or the drain in the back is frozen over . clean the drain with hot water and a turkey baster . they get algi in them the the water can't get down the drain . once the drain is clear it will work good mm feed back pls ..
Jul 10, 2011 | Amana Refrigerators
Top shelf not freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 27, 2010 | Freezers
There seems to be water accumulating on the top shelf of our fridge. items on the top shelf get wet and the water also ends up dripping on the floor after awhile. we have not got the ice maker hooked up
YOUR DEFROST DRAIN IS EITHER CLOGGED WITH ICE OR GUNK, YOU CAN UNPLUG AND DEFROST, THE ICE THIS TAKES SOME TIME. AS THE OPENING FOR THE DRAIN IS IN THE CENTER BACK BELOW THE EVAPORATOR. AND THE ICE MAY BE FROZEN FOR 5-6 INCHES INSIDE DRAIN. YOU WILL SEE WATER DRAINING INTO THE PAN ON TOP OF COMPRESSOR WHEN AND IF DRAIN IS CLEAR. IF NOT ICE THEN TRACE DRAIN FOR BLOCKAGE. SOME FRIGS HAVE A SMALL PIECE OF PLASTIC AT BACK OF FRIG THAT PULLS OUT AND HAS VERTICAL SLOTS TO KEEP OUT DEBRIS, THAT WOULD BE WHERE GUNK WOULD BE.
Mar 10, 2010 | Refrigerators
Frost on the back of the rerfergerator inside on
hi
it may be compressor or thermostat problem,,,u should check it..
thank u,,///please rate it
Jul 04, 2009 | Refrigerators
Top lowering problem on 2004 Saab Aero Convertible
I have a 2004 Saab 9-3 Arc convertible that had the same problem. The spring on the hinge assembly for the package shelf latch assembly was broken. The part itself is over $300. If you have someone remove the spring, your top will work again. You'll just have to put up with the top shelf hanging down in your trunk about 1 foot, but you can still manually move it to place things inside like your luggage or golf clubs.
Apr 23, 2009 | 2004 Saab 9-3
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
78 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
