Question about Mantis 2-Cycle Tiller
Mantis tiller choke out with choke off
Starts and idles but when the choke is disengaged the engine shuts off.
Replaced all carburetor seals, gaskets, and diaphrams. Replace fuel hoses and fuel and fuel filter, Also checked and clean exhaust system. Has new spark plug. Engine stalls if it is accelerated too far above idle. Cannot get full power. Vent Fuel filter is clear and clean. Tried to adjust (per manual) the idle screws in the carburetor but the motor still stalls when accelerated or the choke is pushes in. Tines are seated and turning properly. Even took off carburetor and blew out ports and valves.
  • Kelly
    Kelly May 11, 2010
    This sounds like the problem many not be the carb, however. Which engine is it? 22 CC honda 2 stroke or 4 stroke ? There are several engines 22, 33, 49 cc I don't really want to discuss each one of them and what could bre causing the problem. f almost sounds as if your float needle is sticking in the carb. The float needle would be on top of the diaphram, If you would... Please pass your engine model number so someone can better assist you. Kelly
SOURCE: Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Posted on Jun 01, 2009
  • 15 Answers
SOURCE: Engine runs fine on 2-cycle Mantis tiller, but
Your problem is a common one on Mantis tillers. The engine sounds like it is not breathing properly. I have fixed dozens of these problems and it is almost always the spark arrestor clogged up. The spark arrestor is found inside a small housing on the muffler (easy to fix). There are 3 screws that need to be removed to get the muffler cover off, then you will see a small housing a little over an inch long with another 3 screws...remove them and you will see a small screen that is probably clogged. Clean it and the housing with a solvent (I usually use carb cleaner) then re-install the arrestor and reassemble the muffler cover. This will fix your problem about 80% of the time.
If that is not the problem you may need to fix the carburetor (take my advice and just buy a new one...not much more expensive than the repair kit and a lot simpler.
Posted on Jun 14, 2009
wolfwizard11
  • 5 Answers
SOURCE: MANTIS WILL NOT IDLE
I had the same problem. I adjusted the throttle stop IN until I got an idle without touching the throttle.
Posted on Aug 04, 2009
lindsay836
  • 677 Answers
SOURCE: Mantis tiller 2 cycle will not accelerate. idles
I would pull the tines off of the transmission. You probably have some debris wrapped around the transmission drive shaft(s).
Please let me know.
Posted on Feb 08, 2010
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
I have a briggs an stratten engine on a tiller that will not stay running
It sounds like the air supply. Check the air filter.
Jul 02, 2014 | Mantis Tiller
Mantis tiller Idles fine, and can even rev... sometimes, but has no power.
check the diaphragm in the carburetor making sure it isn't stiff. depending on how long it has sat, the carburetor may need a cleaning and kit then readjust it to get it to run. Mantis tillers are very temperamental and can be difficult to get to run again even for experienced technicians
Feb 25, 2013 | Mantis 2-Cycle Tiller
My tiller will run with choke on but soon as i shut choke off it dies. How do i solve this problem.
First make sure the fuel filter is clean. Check the carburettor is attached tightly to the engine. The passage ways and jets in the carburettor may be gummed up. Dismantle the carburettor while ensuring that you don't damage any gaskets. Spray carburettor cleaner into the orifices and then if you have a compressed air gun, use it to blow out the carburettor.
Jun 23, 2011 | Mantis 2-Cycle Tiller
Mantis starts and runs but lacks power and is slow to rev up
Check the air filter and ensure it is clean, replace if necessary.Foam filters can be washed in hot water and detergent, paper filters need to be replaced.
Ensure the throttle cable moves freely and the choke is turned off after starting.
Mar 08, 2011 | Mantis 2-Cycle Tiller
Machine runs fine for approx 20 mins. Thereafter when drive is engaged will run for 20 seconds before engine starts to die .If drive is disengaged engine will idle fine until drive is engaged and problem...
your engine is starving for fuel supply. Remove fuel line from carburator. If fuel flows from line remove carburator and clear obstruction from needle valve and insure that fuel is not being restricted. If fuel flow is slow: clean and rebuild if necessary the fuel pump (if applicable) or follow fuel line to fuel tank and remove blockage: in line fuel filter fuel, tank strainer, or on and off valve that may be choked off.
Mar 02, 2011 | Mantis 4-Cycle Tiller
Mantis tiller rpms shoot way high with slight increase in throttl
It is leaking air into the intake somewhere or
the rings are shot
the crank seal is shot
the crankcase gasket leaks.
Jun 08, 2010 | Mantis 2-Cycle Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
What kind of engine is it ? Does it have a float carburetor or diapram carburetor ?
May 09, 2009 | Mantis 2-Cycle Tiller
Mantis tiller dosnt run right
The carburetor needs to be removed, soaked in a cleaner fluid for a couple of hours, reattached and then adjusted.
May 02, 2009 | Mantis Tiller
Mantis 2-Cycle Tiller Logo
184 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
