Question about GE Kitchen Ranges
I have a GE electric range Model#JSP42 N2SS. It is beeping once every minute,even unplugged. We had a thunderstorm just prior to it starting this. Nothing else in the house was affected. any ideas?
jsrock516
  • 5911 Answers
SOURCE: BEEPING OVEN
The F1 and constant beeping is an error code indicating that your electronic control board (clock/timer) is defective. The fault cannot be reset and the control board must be replaced. This can be an expensive repair if your range is no longer covered by a warranty or service plan. The cost to buy a new control board can be in the neighborhood of about $200. Sorry...but I do hope this helps you.
Posted on May 12, 2007
jumptrout51
  • 3361 Answers
SOURCE: GE RANGE WONT STOP BEEPING EVEN WHEN IT IS UNPLUGGED
Replace the electronic control.
Posted on Feb 21, 2009
fixyourboard
  • 310 Answers
SOURCE: I have an electric range, model # J SP42SOK4SS.
This means the controller is sensing a stuck key, which may be due to an actual stuck key or a problem with the controller. There is a way to diagnose which is the cause if you are comfortable tearing into the unit, or a repair tech can quickly diagnose for you. If you need a controller, you might consider having us rebuild it for you.
Regards,
Bruce
www.fixyourboard.com
Posted on Oct 10, 2009
  • 969 Answers
SOURCE: I have a 3yr old GE range JSP42 F7 E6 cade
http://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
SOURCE: Self cleaning will not work
I have the same range also about 2 years old and the other day tried to do a self clean cycle and my door lock won't engage either - would love to hear any ideas as well. Thanks!
Posted on Jan 07, 2010
I need instructions on replacing the glass cooktop for model number. Jsp47sh2ss
Looks like you have to access it from the back removing the mounting trim screws # 769 and trim #37 then continue with trim #50 I have Not replaced this exact unit but it looks same same as other units I have worked on900
Apr 18, 2016 | GE JSP42 Electric Kitchen Range
Does the replacement (GE infinite switch WB24T10026 for model JSP42SK4SS) come with installation instructions for taking the bad unit out?
No, when you buy a part there is no instructions . Manufacturers want you to call an authorized technician these days so they will not provide you with any instructions
Mar 14, 2011 | GE JSP42 Electric Kitchen Range
GE Stove. Model: JSP42S K5SS Problem: Left front burner is always on even turn to Off posittion. The burner indicator is on and the surface is alway hot. The stove is only 2 years old and well...
This is most certainly the infinite switch. If you pull the knob off for this eye, the shaft you see is part of that switch. You need to disconnect power to the appliance and replace it.
Nov 04, 2010 | GE JSP42 Electric Kitchen Range
Ge jsp42 electric range ..Oven heats up very slowly..sometimes can take one hour to heat to 400 degrees..Stove top also slow..
Check the voltage at the outlet. It should be 208v or 240v. check by putting meter probe into the 2/3 slots. NOT the U shaped,or round looking holes.Check one to another. Check tag on range for voltage of range. If you have 208v at the outlet and range is 240v the oven will take forever to heat, it is not getting the power it needs. If the tag says 230v either will work. On the oven tag it will say either 1ph, or 3ph. If it says 3ph you outlet should have the voltage mentioned above between ALL 3 SLOTS! If you get 120v when testing any slot, you have only 1ph of power. Keeping it simple, the ph, (or phase,) between the outlet and oven have to be the same.
Mar 31, 2010 | GE JSP42 Electric Kitchen Range
Jan 02, 2010 | GE JSP42 Electric Kitchen Range
F2 and F3 Errors just started on my GE Electric Range
I had to clean the contacts in the control panel to fix my same problem.
Nov 10, 2009 | GE Kitchen Ranges
F7 error--ge range
sometime if you pull the unit out. there maybe a screw on each side of unit. carefully lift the panel upward.
May 08, 2008 | GE JSP42 Electric Kitchen Range
Keypad Start and Clear are the only keys that work. F7 S6, S7, SA, d6
f-7 mean stuck button on key pad or stuck relay on oven control. if the problem started while oven was in use replace oven control. if problem started while oven was not in use replace key pad
Nov 19, 2007 | GE JSP42 Electric Kitchen Range
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
