Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Top dishwasher drawer will not drain the water and now has a setting that cannot be changed past 5 min cycle ...LED readout shows a wrench. what is the problem?
  • 523 Answers
Drain pump
Posted on Apr 25, 2010
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Haveing a u3 code on my top draw of my fisher & paykel any help on this
First have the unit turned off. Then open up the drawer that,s giving you trouble.
The badge ought to be lit.
Now simultaneously press the static touch pads on each end of the led status lites (the ones on the drawer top?) (Cycle Select, and Eco-sensor pads)
Hold them for about 5 seconds.Now If you have a metal front machine, the badge display will either show HP or LP. Assuming you have normal water pressure about 50 - 70 psi you want to select the HP setting.
Do that by pressing the start button till you get what you want, then press power off to lock the setting in.
Mar 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
TOP DRAWER WAS NOT DRAINING..NOW THE F1 ON BOTH DRAWERS IS ON
F1 code indicates a leak,you will find the water under bottom drawer.Lid probably not sealing well.
Jun 17, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
F3 error showing
F3 means the Dishwasher thinks it's water temperature in the tub is over 80oC. So when the unit stops see how hot the water is. The unit has a temp sensor which is part of the element which maybe faulty, the element maybe faulty or the Motor controller module is faulty. I'd try the Motor Controller module first as replacing the element can be a tricky job if you haven't done one before. If you have a double dishdrawer you can swap over the Motor Controller modules (main computers in the front of each drawer) as the top and bottom are the same part, inturn you will prove 100% if this is the fault or not without buying a new controller. Cheers
May 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water in top drawer
I am not a repairman but have installed several duel drawer dishwashers. Most dishwashers have a check valve preventing backflow. Water under pressure will always follow the path of least resistance and in your case it is going into the upper drawer. Be sure the drain is open and flowing easily under your sink whether that be the disposal or a TEE. It may help if the drain line is elevated as high as it can go under the sink just before it reaches the drain. How often do you use the top drawer? Perhaps run a cycle on the hottest cycle without dishes to attemt to clean or force through any contaminants in the check valve through into the drain. Hope this helps, Ken
May 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Fisher & Paykel DD603 setting the water pressure
First off, clean the surface where you select the cycles, over on the right side of the drawer edge. Clean up the entire surface, so that when you lightly touch the cycles, It changes instantly. Also, you said "dd603" but the LP/HP modes are for model 601 and 602.
Open the drawer, select normal first. Now with two hands, hold your fingers over the two outer-most buttons, one on the left side and one on the right. Wait up to six seconds and then the LEDs should all come on in an orange color and the display should show the LP. Press the lock button once, it should change to LP. Make sure you are looking for a manual for a dd601/602. You can get them free at http://www.fisherpaykelparts.net
Dec 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
129 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
