Question about Samsung WF337AA Front Load Washer
Hello everybody, I have a Samsung Fuzzy logic WA13R3 topload model. The michine shows the error code "t01" and doesn´t start, better to say, the any button on the pannel doesn´t respond. Thanks.
5 Suggested Answers
SOURCE: Error Code 1 on samsung fuzzy
MAYBE PUMP BLOCKED
Posted on Oct 25, 2008
ginko
  • 19396 Answers
SOURCE: my toploader "fuzzy logic" 6.5kg
Hi.
If there is no spin, c licking noise before spin may come from a relay in control module, from lid switch motor, or from the fuzzy logic control unable to start drain pump. This last problem may occur because of residual water inside the machine tub.
You should run a diagnostic cycle. The procedure is explained in user manual. LG should use the following:
Press Spin and Temp. and Power buttons simultaneously to enter diag. mode.
At the end of the process you should get an error code that will tell you what the problem is. If there is a code already, then please let us know the code.
Posted on Feb 01, 2011
  • 500 Answers
SOURCE: Can't unlock my child lock
Hi siphethina,
Follow my tip below on how to disable Child Lock:
L.G CHILD LOCK..
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Posted on Sep 11, 2011
Testimonial: "It's amazing it did work, thanks a million and have a nice day"
  • 45295 Answers
SOURCE: My fuzzy logic samsung toploader gives me a PE message.....what does it mean?
try searching Google for that error
Posted on Jun 02, 2015
Samsung Fuzzy Logic Washing Machine will not rinse and is showing an OE sign . What is problem and how do i fix it
The OE code indicates an Overflow Error. Too much powder or liquid detergent may have been added. If you turn off power, wait 30 seconds, and turn on power, the pump should turn on to drain the machine. If this routine doesn't work it may be necessary to call for service.
Nov 27, 2016 | Samsung Washing Machines
Samsung fuzzy logic machine is showing 0E error sign and will not rinse
The OE code is an overflow error that occurs when too much detergent has been added. Samsung recommends turning off power, waiting for 30 seconds and turning power on again. You should hear the pump drain the machine.
My toploader machine is not rinsing or spinning the model is a LG Fuzzy logic WF-T7014pp
if it does not rinse its a different case,,,,,nd if it does not spin is another ,,,check on the door lid,its a magnet,,,,,,,,,,,,,,,,,attached the washer pic ,,,so i can tell u what to do............
if u have a magnet tryputting it between the door and its main program board,,,centre nd try
Jan 23, 2015 | LG Washing Machines
REQUIRES MANUAL FOR LG FUZZY LOGIC TOPLOAD WASHING MACHINE MODEL NO WF-T7030TP
The service manual is hidden inside the unit or inside the console.
Oct 22, 2013 | Washing Machines
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Doesn´t scan or print; error
The 5100 error on this printer can be caused by a bad/faulty Carriage Unit, or Timing **** Film, or Logic Board, or Carriage Motor. If your printer is blinking only 2 times then a pause then blinks again 2 times this is more then likely the issue. You will need to contact Canon and find a repair center near you to fix this issue.
1-800-828-4040
or
1-800-652-2666
Best of luck..
Have a Happy and Safe Holiday Season...
Dec 01, 2010 | Canon MP520 All-In-One InkJet Photo...
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Samsung WF337AA Front Load Washer Logo
122 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
