Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Electric blade switch when engaged does not operate blades
  • rjnmartinez Apr 26, 2010
    thanks found problem fuse
  • 2,100 Answers
Does it do anything when you hit the switch?? Make noise,? spin? Tractors now days have a bunch of safety switches on them that prevent the mower from spinning if all isn't right. You have a switch under your seat, you have to be in the seat for it to work, the clutch might have to be in, the brake may have to be on, lastly, the belt may be off. Just because it is an electric switch, it is still belt driven. Check it out.
Posted on Apr 24, 2010
Testimonial: "have done all still does not operate"
  • Ned  White
    Ned White Apr 26, 2010
    OK then, you have a couple fuses near the battery, they are always corroded from the battery fumes. Check them out and check out the connections as well. Mine has the electric switch, but I never had a problem with it. If you can't get it going, I'll go out there and dig up the next thing to try. Hope this helps.
  • 86 Answers
SOURCE: blades will not engage when you pull up on the button
When you pull switch to turn on blades do you here a click sound ? If so clutch is most likely ok,did you check your belt to make sure its ok ?Seat switch is just a saftey feature it cuts all power to the clutch so thats why blades turn off,thats why I asked you if you here a click when pulling switch that will tell you if there is power to switch.there is also most likely a fuse in the line that goes from the clutch switch to clutch.
Posted on May 12, 2009
  • 4 Answers
SOURCE: dies when blades are engaged
Is this on the grass, grass may be too long stopping blades from moving.
Posted on May 18, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 143 Answers
SOURCE: When I engage the blades the eletric clutch kills
Check the grassbox switch, it might be faulty
Posted on Jul 04, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
Husqvarna yth 170 problems when engage blades clutch nothng happens
On the 170 there is an electrical clutch that enables the blades to engage. This of course is an important safety feature.
If the operator is not sitting in the seat the switch located beneath the seat will not actuate. It is possible that the weight of the operator is insufficient to activate the switch. Other possibilities are the connection to the switch has become disengaged, or the switch has failed.
There are other possibilities of why the blades do not engage but I would evaluate the seat switch first and the relay (operator presence relay) that the seat switch activates second..
Nov 28, 2015 | Husqvarna Garden
The mower blades are engaged at all times. The switch that disengages blades does not work. A safety issue exists. What can you advise?
Sounds like the switch is defective and must be replaced..in the meantime...locate the wire connecting to the electric clutch fro the bad switch, shut the mower off and disconnect the wire from the clutch..you can operate the mower when not using the blades....just remember make sure you shut it down before attempting to pull the wire off the clutch..this is only a Temporary fix...good luck..
Jul 28, 2015 | Husqvarna YT48XLS 48 inch 24 HP Kawasaki...
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
Why mower blades will not engage when buttom is pulled
I believe this one has an electric clutch. Check to see that the switch is operating properly, that the wiring is good to the clutch, and that the clutch is good. Use a volt meter to check that there is voltage to the clutch when the switch is operated.
Jul 15, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Safety switch located
Micro switches will just stop the engine if the blades are engaged and the operator leaves the seat, or will stop the engine cranking if the blades are engaged, it will not stop the blades from engaging.
Sep 06, 2012 | Murray Garden
Leplease explainon the safety switchs on mtd models660-679 work? I beleave my model is an intek twin. thank you
The safety switch beneath the seat is only one part of the several interconnecting safety features of the modern riding mower. If the system works properly, you must be seated for the mower deck to operate. The tractor will continue running with the Power Take Off disengaged if the parking brake is set before the operator leaves the seat.The seat switch consists of two electrical contacts normally separated by an air gap. A spring creates an open space between the two contacts. Mounted between two plates, the switch's spring compresses under the weight of the person sitting in the operator seat and completes an electrical circuit. With the switch closed the tractor's ignition system can be switched on with the ignition key. If the operator stands, the spring forces the gap open and interrupts the electrical ignition circuit. The safety circuit allows the riding mower motor to continue running if the PTO is not engaged. When the parking brake is set a second switch in electrical parallel with the OPS closes. This bypasses the safety switch under the seat. If the operator stands, the parking brake switch still completes the ignition circuit.The mower blade turns only when the PTO engages. If the operator should leave the seat with the blade turning and under power, injuries could result. The mower blade would even continue spinning at full power if the machine overturned. To prevent this type of accident, engaging the PTO deactivates a connection in the original circuit and completes a second circuit in series with the OPS switch.
If the operator leaves the seat with the PTO engaged, the ignition interrupts and the machine stops. Until the PTO is off, no combination of settings will restart the mower.
Apr 05, 2011 | Garden
Replaced belt for mower thought i put it all back correctly blades engage when key is turned engage lever to off what did i do wrong
If you look at the motor pulley area, there should be two different pulleys with a PTO clutch between them. The PTO clutch has wires going to it, because it is operated electrically by the blade engage switch.
It sounds like you could have accidentally put the mower deck belt onto the main drive pulley (which turns all the time) rather than the pulley that is farther out from the engine, which only turns when the engage the blade switch. If so, just loosen the mower belt and move it to the right pulley.
Jun 09, 2010 | Garden
Have a cub zero turn 52 inch cut the blades wont engage it starts but when you pull the switch to turn on the blades it wont engage any help?
sounds like one of three possible problems ....one - there are safety switches that prevent engagement of the blades,,,,,two - the electric switch which engages the electric clutch blade pulley is bad....or three - the electric clutch blade pulley assembly is bad.....first.....make sure all ur connections are tight to the safety switches and electric clutchblade pulley.....then, if your able to read and follow a wiring diagram, get the wiring diagram for your tractor and a 12 volt probe light (with probe point end) with a ground lead....first, ground the clamp end to the frame and probe at the electric pulley clutch plug to see if power is getting there...if not...follow the wiring diagram to the next switch location the power lead comes from....if one side of the swtich shows power and the other side doesn't with the switch in the correct run position....then the switch or connection is bad.....if it probes okay...go to the next switch....follow this logic from both sides of the from the electric pulley blade clutch plug until you isolate the switch or plug problem....if everythin tested is good....then it's the electric clutch pulley assembly that need replacing.....hope this helps.....
Jun 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
138 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
