Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Refrigerator light bulb is new but will not light. When I screw in bulb, indicator lights shut off as well.
    Sergeant:
  • 239 Answers
Need to change board down on left side of compressor in back
Posted on Apr 25, 2010
Replced bulb starts to power then fail red light blinks thre times
You might need a new housing! Sometimes, the housing can be damaged with a new bulb and it can caused the TV to want to shut off.
Mar 15, 2013 | Sony KDF-E60A20 60 in. LCD HDTV
REPLACE LIGHT IN FRIDGE
- Unplug the refrigerator from the electrical outlet.
- Locate the bulb on the inside of the refrigerator.
- Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
- Unscrew the old light bulb.
- Screw in the new light bulb.
- Replace the light cover. Plug the refrigerator back in. Test your new light bulb.
Hope this helps, please rate if the solution was helpful, thanks!
Oct 08, 2011 | Refrigerators
How to change light bulb in ge refrigerator model gts18dbpalww
Unplug the refrigerator. For the refrigerator, unscrew the old bulb or bulbs and screw in a new appliance bulb of equal or lower wattage. For the freezer compartment, if a lamp is present, squeeze the top and bottom of the cover together then unscrew the bulb. Then screw in a new appliance bulb of the same wattage and replace the cover.
Note the appliance bulb is an incandescent bulb and may be hot.
The manual is available here: http://www.managemylife.com/mmh/owner_manuals/5791/GE-Top-Mount-Refrigerator-L0307014?brand_name_search=gts18dbpalww+ . The lamp replacement is given on page 13.
I hope this helps.
Feb 14, 2011 | GE Refrigerators
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Step 4
Step 5
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Refrigerator works but no interior lights new bulbs
I have the repair manual and will be back soon. I am looking over the possibilities.
Apr 30, 2009 | Hotpoint HSS25GFP Side by Side...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Replace front driver signal light bulb
Depending on whether it is the front or the back turn indicator light will determine on what needs to be done. If it is the front turn indicator light open the hood of the car you may need to take the entire headlight out. The headlight may have screws, take the screws out then the front light will come out from the outside of the vehicle replace the burned out bulb. The bulb should snap right in and then put the headlight back in make sure you put all screws back in from the inside of the hood. Step2 If it is the back turn indicator light, go through the trunk of the vehicle. If there is a panel covering the lights you must unscrew the panel and then replace the burned out light bulb. Some panels can be folded down without removing all of the screws to access the lights. This light may not require for you to pop the entire light out you maybe able to just replace the bulb. After you have replaced it screw the panel back into place. The back light should not require the entire light to be lifted out just a simple bulb replacement. Step3 In replacing either the front or the back indicator light you must gain access to the turn signal housing which is usually in the same case as the headlight or your rear lights. It is very helpful to also get the owners manual out this will tell you exactly what type of bulbs you will need to get to replace the indicator bulb.
May 29, 2008 | 2005 Cadillac SRX
Magic chef #rb19k-4a refrigerator: bulb replacement
unplug refrigerator look inside light socket youll see a tab in the bottom of the socket bend tab up alittle bit then screw light bulb back in. if this doesnt help then the door switch is bad
Nov 21, 2007 | Refrigerators
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
