Question about Radio Shack Pro-2096 Base Scanner
Reception Sounds like someone is talking underwater on some traansmissions.
  • mtms Aug 24, 2008
    better reception
    Scholar:
  • 66 Answers
Simple off-channel interference, tell the scanner to skip or lock out the frequency, unless that's how it sounds on every frequency. If it does sound like that on every frequency, you may have a busted speaker, use an external speaker instead.
Posted on Jul 04, 2008
BPR40 Receiving a static reception when someone is talking
Several things need to be checked. Fully charged battery. Antenna, make certain it s tight and unbroken. Wiggle the antenna while receiving, if reception improves, it is the antenna or the antenna jack. Then wiggle the on/off vol switch, same thing, if reception improves, it is broken or needs to be resoldered. Then I check the speaker. Speakers gather metal particles, as they get more and more, the speaker distorts and it sounds like static. Use a powerful magnet, run it over the speaker grill and see if anything comes out. I put plastic wrap on the magnet for easy cleaning. It could still be a bad speaker. Last, I check programming. All of this is done at our shop regularly and I suspect most radio shops follow the same procedures, maybe in a different order. Post if this helps or not.
May 17, 2016 | Motorola MagOne BPR40 UHF 8-channel...
Why is my iPhone 4 say no service when other strait talk member have service in the same area
Remember that antenna issue that the ip4 had? Sounds like that antenna problem to me. I heard cover cases made the reception even worse. Try to take the cover off in that no service area and hold the phone with the tips of your fingers and see if the reception is better. If it is, go to the apple store and ask how they resolved the antenna block problem with your model of I phone. Good luck
Mar 27, 2015 | Cell Phones
Why is it only abc tv have a weak quality signal & reception
sounds like an antenna problem. rotate it with someone who can tell you how TV is affected by rotation. Some people buy an antenna motor for reception.
Feb 16, 2015 | Televison & Video
Skipping
It's most likely a line problem, not a phone problem.
Try isolating by plugging another phone to the line. If you still here the bad reception, then the line is dirty and you should report this to the telephone line provider.
Aug 07, 2009 | Lands Phones
MOTO Razor v3m with bad speaker outgoing.
the microphone on the phone needs to be replaced so take the phone to a mobile repair shop and have it replaced
Dec 25, 2008 | Motorola Mobility RAZR V3
Toshiba 42H 94 speker sounds like its underwater
There may be a fault with the speaker driver, or the output stage circuits, or the audio decoding circuits.
Without proper troubleshooting, it is impossible to pin-point the exact fault.
Jerry G.
May 16, 2008 | Toshiba 42H81 42" Rear Projection...
AUDIO SOUNDS LIKE IT IS UNDERWATER
Try changing the EQ to None. As the EQ tries to enhance sound hope this solves your problem
Feb 23, 2008 | SanDisk Sansa e260 MP3 Player
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Radio Shack Pro-2096 Base Scanner Logo
116 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
