Question about Imperial IFS40 Deep Fryer
Imperial cif 40 single tank bouble basket deep gas fryer
Hi
actually i have one imperial cif40 gas fryer ,when heated up goes off totaly ,include pilot ,the engeenier change the control thermostate, but stil same problem.could you tell my what's wrong whit this fryer.
thankyou.
ally
  • mahnaz43 Apr 25, 2010
    the fryer it has'nt got the control board.just control ther,hi limit ther,robertshaw multi funection gas valve,thermopile and thermocople
  • 3,740 Answers
When the whole unit shuts down including the pilot light the thermocouple is not working properly. The thermocouple is what tells the gas safety valve that the pilot light is lighted. When the thermocouple fails and does not send the milli-volt (mv) signal to the gas safety valve due a failure the gas safety valve turns off the gas supply. (i.e total shut down)
If you have a handyman around you can have him disconnect the thermocouple from the gas valve control and clean the mating area in the gas valve and on the bitter end of the thermocouple. After cleaning then reconnect the thermocouple. This sometimes corrects the problem. FYI you can get a thermocouple at most any large appliance parts supply. (You will need to the know total length) It would be even better to have the old one in hand during the trip to the parts store.
Thanks for using FixYa,
Kelly
Posted on Apr 25, 2010
  • 2 more comments
  • Kelly
    Kelly Apr 25, 2010
    You mentioned: when heated up goes off totaly ,include pilot
    The solution I provided will most likely correct your gas fryer problem IF it is the thermocouple type unit.
    However.... if the pilot is electronic on your gas fryer (i.e a glow bar type ignition), then the signal that on the older type gas units that was controlled by the thermocouple is controlled by "The flame sensor." If the "Flame Sensor" fails, the signal to the gas safety valve is lost and the unit will stop operating because the gas safety valve will shut off the gas supply. It is also possible to have a poor connection on the glow bar or a defective glow bar that fails when it s hot. Either way that too can result in non-operation.
    A weak gas valve solenoid (one of 2 ea) can also cause total shut down.
    There was no client feedback as to the reason for rejection of Kelguy2002's Solution #1
    Still trying to help you,
    Kelly
  • Kelly
    Kelly Apr 25, 2010
    Thermocouples for Imperial units can be found here:
    http://www.3wire.com/webstore/Parts/Part...
    If you have a part number it is even better. If not... lenght per listing
    You will have to create an account. "Its free"
    Kelly
  • Kelly
    Kelly Apr 25, 2010
    The Thermopile can be found here:
    Again you will have to have an account or create one. It is free.
    Kelly
  • Kelly
    Kelly Apr 25, 2010
    You mentioned the Tech replaced a thermostat. Cooking control thermostat or High Limit thermostat? The high limit Thermostat OEM PN 1177 will also shut off all gas supply.
    It is going to take a meter to find out where in the circuit the open has occurred.
    Source power to temp control and gas safety valve
    Gas safety valve solenoid control
    Thermopile control
    Proper function of the Thermocouple in mv
    High limit thermostat function.
    temp control to ground
    I am still sticking to most probable suspects as the High Limit Thermostat #1 or the thermocouple #2.
    Kelly
  • 2,926 Answers
The high limit is a safety device on all fryers. For your fryer it is mounted on the right side inside the door. Push in on the red stem sticking out of the front of it. If it is tripped you will hear a click when you push it and then the pilot will probably stay lit. If it is a case of the high limit tripped....then you need to check your thermostatimperial cif 40 single tank bouble basket deep gas - 2_bing.gif and make sure that it cycles the main burners off at the set temperature.
  • 1,284 Answers
Hi, from the above question, the problem is not with ht thermostat but with the control board. The control board fails to hold onto power when the device is heated up, that why it goes off automatically..
Take care
Testimonial: "thats perfect.thank,s"
    President:
  • 2,030 Answers
Sounds like the high limit switch is bad, and causing the unit to think its overheating. Have that checked, i bet thats your problem.
Posted on Apr 24, 2010
    Brigadier General:
  • 3,513 Answers
Hi
Yes it is a problem with the thermostat. The reset button is probably in a high limit. The high limit is a safety device to turn the fryer off if the oil gets too hot. Normally they will "trip" somewhere between 375 - 450 degrees F for commercial fryers. I would suggest placing a temperature probe in the oil and see what the oil temp is when it trips. If it trips at a temp below 375, it is a bad high limit. If the thermostat is set at 350 and the temp goes over 400 then the thermostat is bad.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Pilot goes out after fryer reaches operating temp. Replaced milli-volt generator already.
sometimes the hole in the pilot tube gets dirty and needs cleaned in the old days the gas man had a tiny drill bit he reamed it with .
Mar 05, 2015 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Need a wire schematic for a deep fryer gas valve elite efs 40
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 28, 2015 | Imperial EFS-40 - Gas Elite Deep Fryer -...
Imperial gas 40 lb fryer, replaced thermostat, now when you set the dial at 250 the oil heats above 375 and keeps climbing. What now?
Sounds like you have installed the wrong thermostat, or it's a bad one... If you need further help, please call us at 888-542-5959. If you have the model/serial number, we can make sure you have the right thermostat and/or get you the right one... Thanks, Susan REO reocincinnati@yahoo.com
Aug 23, 2011 | Imperial IFS40 Deep Fryer
Flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Tom
Jul 23, 2010 | Imperial IFS40 Deep Fryer
Hi actually i have a cifs40 deep gas fryer and recently i change the control thermostat,now when turn the pilot on ,after 15 second the pilot stay on,but when turn the control valve knob to on position...
Take care
Apr 26, 2010 | Imperial IFS40 Deep Fryer
Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Fryer will not fire
The coil in the valve is barely being held closed. Most of the time, 90%+, the thermocoupler (or thermopile) is bad.
You can clean and check the connections, and test it again. Otherwise, spend $20, and replace the thermocoupler. (thermopiles $50) Reason is, a gas valve will likely cost $250 or more. Good luck - Mike
Jun 25, 2008 | Imperial IFS2525 Deep Fryer
Imperial IFS40 Deep Fryer Logo
754 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
paulcarew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
