Question about Moen T991 Chrome Chateau Double Handle Roman Tub Trim with Porcelain Lever
Spout for Moen T991 doesn't fit valve 9993 - Moen T991 Chrome Chateau Double Handle Roman Tub Trim with Porcelain Lever
  • 20 Answers
The moen T991 fits a valve number 9997 or 9999
Posted on Apr 29, 2010
I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
How do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
When the shower valve is engaged I still get water out of the tub spout and limited water out of the shower head. I just replaced the cartridge thinking that might be the problem but no luck
it sound's like you need to replace the tub spout.there should be a set screw on the bottom of spout loosen and twist off. replace with moen spout for ease of re-install.it's a real pain in the *** to try and replace -o- ring spout.
Dec 05, 2009 | Moen & One Handle Tub & Shower Faucet
I have a moen fawcett. single knob, it is leaking
the spout is the end piece where the water comes out. where is it leaking ?.
when you put it back together i would suggest you use some teflon tape often called plumbers tape on all the theaded fittings as that will prevent any leaks as well.
Nov 27, 2009 | Moen & One Handle Tub & Shower Faucet
Replacing Moen O kitchen faucet O ring
if it is dripping from the spout then there is a cartridge that needs replaced...1225 for the single handle type and 1224 for the 2 handle type. Moen does not use O-rings in their valves. If it leaking around the base of the spout there is an oring kit that you will need and you will have to pull the spout off to access them. Most Moen faucets use a 117 kit for the spout but there are some different ones.
Oct 19, 2009 | Moen & Replacement Cartridge
Moen Tub Filler Can't Remove Spout
It should lift off gently twist as you lift maybe tap spout lightly back and forth with a rubber mallet
Oct 14, 2009 | Moen Kingsley Two Handle Roman Tub Faucet...
Moen T991 Chrome Chateau Double Handle Roman Tub Trim with Porcelain Lever Logo
75 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
