Question about HP DeskJet 970cse InkJet Printer
Blank print I am connecting my printer to the computer through a USB cable. When try to print it just comes out blank. what could be the reason?
  • 52 Answers
If there is print movement then the printer is fine check if the ink cartridge is not blocked. Do a cartridge clean
Good luck
Posted on Apr 24, 2010
Printer not connected to computer
If you are using Windows you will get a chime sound when you plug & unplug a usb cable. I would try using a different USB port on the laptop and see what happens. Did the dog/cat/hamster chew on the cable maybe? I would also try another USB A-B cable.
Mar 08, 2014 | Kodak Office Equipment & Supplies
LexMark e321 printer is printing blank pages. I changed out the ink toner, reinstalled the driver from the E321 disk, changed the USB cable and still get 2 blank pages and the LED button by error is...
Try to disconnect all cables from the printer and leave it off for about 30 seconds to clear the print job. Turn the printer back on and check the status lights, error light stop blinking then try connecting the printer back to the computer and try printing again.
For further assitance, please contact Lexmark Technical Support
Jul 20, 2011 | Lexmark E321 Laser Printer
My kodak 5100 all in one printer will not print out my documents but only prints out what is on my scanner, how do i solve this?
did you recieved an error message printer not responding? If yes please double check the icons of printer on the printer and faxes, if you can see 2 icons delete both icons and unplug your USB cable, then restart computer.
Now if the computer is already restarted connect USB cable then try to print.
there are several reasons why it will not print using computer, there might a problem on USB cable and its connection or the drivers., Please verify the problem, or you may contact kodak toll free 1 800 421 6699. hey will help you on this issue., Gudluck!
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Just purchased esp printer, does this have to be
You do not need to connect it to computer to print photos. the printer, place any document on the scanner glass and put papers in the document tray and press copy. if the printer does not work, Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.The usb cable does not comes with the printer and you need to purchase it additionally
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a zebra 110XiIII Plus 300 DPI printer that is randomly printing blank reciepts. It's connected to the computer via a USB cable. There is no rhyme or reason to the blank printing, just does it...
This is usually caused by the sensors being dirty or the printer needing calibrated. Blow off the media and ribbon sensors and also do a manual calibration. If it is still skipping after this then it is software related.
Jun 11, 2009 | Zebra 110Xi III Plus Thermal Printer
Will not print anything?
Check the cartridges first
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Jan 28, 2009 | HP Deskjet D4260 Printer
I have been unable to print to my lexmark z11 color jetprinter. pages come out blank. I received an error messarge saying : there was an error writing to LPT1 A printer timeoout error occurred. To...
This sounds like more of a communications problem than it does a "time out" problem. I am assuming that the printer is connected to the computer via a parallel cable. If that is the case, try unplugging the cable at both ends, the reattaching it. If that does not change anything, try replacing the cable.
If that does not solve the problem, try replacing the parallel cable with a USB cable and then follow the directions below.
If by some outside chance you have the printer connected to the computer via USB cable you can do one of two things. Replace the USB cable with a parallel cable or change the printer's port settings to use the USB cable. - If you do have the printer connected via USB cable you might be able to rerun the installation software that came with the printer and it may automatically pick up on the USB set up. If not, go to Contro Panel\Printers and Faxes\ - Right click on your printer and open properties. Under properties, click on the Ports tab. Since the error message stated "error writing to LPT1, check to insure that the LPT1 block is checked. If it is, and you are using a USB cable, scroll down until you see two blocks - "USB001 Virtual printer port for USB" and "DOT4_001". Check the box beside "DOT4_001" then click on Apply and close the window. The try printing again.
Hope that helps - Graye
Nov 24, 2008 | Lexmark Office Equipment & Supplies
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
Canon i850
Hello  btfsplk,
Me is Vikram Kumar Thumu from India-Hyderabad. I have seen your message and issue on this issue. I would like to provide my suggestions on this issue.
Generally, this issue could happen if the Port selected that is Printer Properties  is not same as the Port connected to the Computer or Notebook, if this is the case the Printer starts Printing Blank pages from Computer . The issue could also happen if the Printer software is corrupted.
To resolve the issue I recommend you to check and try out below options:
1. try to restart the Print Spooler.
2. Make sure that you selected the correct port in the Ports tab of the Printer Properties.
Example: If your Printer uses USB cable to connect the Computer, then make sure that it is USB001 or USB002 is selected in the Ports tab of Printer properties.
Note:  Make sure that Printer is connected to the USB ports of Computer at Rear End and not in front end. Since, front end USB ports in Desktop Computer are meant for USB flash Drive or other USB devices and not for connecting Printers.
Well, I need much more information of your computer so that I can help you further steps of troubleshooting.
So please let me know below information:
1. Version of Operating System that you are using on your Computer.
2. Please let me know the Printer Model number and Serial number along with Manufacturer.
3. Did you receive any other error messages on this issue?
4. Please let me know cable type ( USB/Parallel) that you are using to connect Printer to the Computer.
Please mail the information at thumuvikram@rediffmail.com, I'll be glad to help you with further information on this issue.
Bye .
Oct 15, 2007 | Canon i850 InkJet Photo Printer
HP DeskJet 970cse InkJet Printer Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
